Hint for wiring; lights, sound, etc.
Old Dec 17, 2006 | 09:37 PM
Old_S-Cool's Avatar
Default Hint for wiring; lights, sound, etc.
If you're going to add any wiring from the engine bay to the interior, DON'T do what I did!
I installed a set of aftermarket Driving Lights, and did a pretty decent job. The Incognocenti would not know the difference from Factory to my aftermarket setup.
However, when I wired the switch to the dash, I only ran the wires for the lighting. It was a BIOTCH!
Afterthought: I should have run a length of 8-10 gauge, and a couple of 14's at the same time. Then, for any future mods, I would have some wiring already in place, and NOT have to go through what I did today again!
Old Dec 17, 2006 | 09:40 PM
Neothin's Avatar
what was so difficult? getting through the driver side grommet is a sinch
Old Dec 17, 2006 | 09:42 PM
SilyOtter's Avatar
make your own hole with a gromet, do a 8ga, and a power distributon under hte drivers seat, also run an accessory turn on and a reulay. and you an run your wiring form one place. have fuses in one place and have it clean as can be!
Old Dec 17, 2006 | 09:43 PM
SilyOtter's Avatar
oh yeah dont forget a ground wire shorter the better froma facotry botl or somewhere and a ground buss/strip/ stud whatever u want
Old Dec 17, 2006 | 09:50 PM
Neothin's Avatar
sorta like i did i ran a 10 awg from the battery through the existing grommet and then into an auxilary fuse panel up under the dash. the grounds all connect onto a ground terminal block and then that connects to 1 bolt to make the ground connection. what are you talking about with relays and such?
Old Dec 17, 2006 | 09:58 PM
SilyOtter's Avatar
hahah looiks like mine .. . i do radios & communications & specialty electrical on fire trucks & amublances & all kidns of emerbency vehicles and thats pretty much how we do small ones.. 3/4 plywood caropeted. 2 6 pole atc fuse holders, a ground ubss. 75a relay so make one buss always hot. and one buss switches. and have a ground strip.. so itl ooks clean and wire it from there.. just do nt forget the labels
ventura city seagrave truck, mdc install w/ isolated battery
Old Dec 17, 2006 | 10:03 PM
exmurderblah's Avatar
that gormmet sucks. its a pita to get ur hand in the engine bay to grab the wire
Old Dec 17, 2006 | 10:15 PM
SilyOtter's Avatar
dont screw around with underhood fuse holders. get a resettable waterproofe ciircuit breaker.. that way its protected.. no stupid melted housings,, and you can turn it off to work on stuf fint eh back w/o takign fuses out n stuff like that
Old Dec 17, 2006 | 10:19 PM
wen I did my underglow I used this thing called add a circuit. connected it to the hazard lights
Old Dec 17, 2006 | 10:20 PM
Neothin's Avatar
add a circuits are nice, but after a while all those individual wires get to be a PITA
Old Dec 17, 2006 | 10:23 PM
SilyOtter's Avatar
well witha good crimp. good wire, and quality termianls.. never had any problems. and that meets gov't spec
Old Dec 17, 2006 | 10:24 PM
I aheva ll my wires hidden. you can see some but only if you're looking carefully.
what size fuse would you recommend for the underglow? I added a 10 amp one.I think that's more than enough.and do you know where I can get a connectiong block? like the one you use for the regular underglow?
Old Dec 17, 2006 | 10:25 PM
Neothin's Avatar
im not saying that it's bad or anything, but i personally feel better knowing that my wiring can't have any effect on the wiring of the car. by using my setup, i never tap into the factory wiring, so if the factory wiring does go bad for some particular reason, the dealer cant blame your aftermarket accessories
Old Dec 17, 2006 | 10:26 PM
SilyOtter's Avatar
.. im not sure what kind of underglow. .LED. 10a should be fine.. . for real neon.. probabaly 15.. just check & see what he kit comes iwth orginally.. .. .. and waht kind fo connecting block.. like theo ne i fhave in my pic?.... and the only factory wire you need.. take it from teh key, from the radio. from wehrever.. is the accessory on wire.. i prefer the radio beczuse its off during start which helps to minimise damage due to voltage spikes on that accessory circuit
Old Dec 17, 2006 | 10:28 PM
Neothin's Avatar
if it's an LED underbody kit, a 3amp will work. I know my flowlighting blaze kit is fused at 2 amps...
Old Dec 17, 2006 | 10:29 PM
any bad about add a circuits
Old Dec 17, 2006 | 10:31 PM
Neothin's Avatar
no, there's nothing bad about them. I just dont like using them because i dont like tapping factory wiring just in case something goes wrong.
SilyOtter's Avatar
those are the stadard intall for all emergency vehicles htat we do. adnt hey exceed govt specs and never had any problems.. . they saay 30 amp max total load. not peak theyre pretty beefy little fuse holders. much bette than the old style addacircuits
Old Dec 17, 2006 | 10:38 PM
they are regular neons NOT leds.the connecting block has 8 slots on one side. 4 for positive and 4 for negative. on the other side it has thisplug that's for + and -.
Old Dec 17, 2006 | 10:40 PM
SilyOtter's Avatar
ive never heard of that style. but if it combines hot & ground.. soudns like an easy one to wire.. make sure you use the same gauge of wire forboth your hot input and ground connections
