Hint for wiring; lights, sound, etc.
Old Dec 17, 2006 | 10:45 PM
exmurderblah's Avatar
its combined. red is hot and black is ground. its easy to install. I can't describe the block with out a pic.
I need help. I have 4 led strips. I want to add em to my engine bay.I need to make my own harness and add a switch. but with a block its easier.where can I get a block?
Old Dec 17, 2006 | 10:50 PM
SilyOtter's Avatar
.. im assuming allt hel ights have thier own posive and negative lead.. no factory harness... personalty ild extend each one to reach the fuse block and power each one individually.. and you can have a realay hooked to whatever swtich you want to turn them on.. id strongly strongly strongly s uggest a realy. dotn stress your facotry wiring for turning on all 4 tubes.. cuz it might not work anyays. where to get one.. any small eelectronics store.. . or marine store.. heres a link.. http://www.westmarine.com/webapp/wcs...key=SiteSearch
..also if your powering an amp in your turnk. runa heavier gauge from teh batt throught eh braker & put an maxi fu se block in teh back.. any car aduio place has those.. they're like a regular atc fuse but just wayy bigger & in higher powers
Old Dec 17, 2006 | 10:56 PM
SilyOtter's Avatar
hopefully this gave you some direction to go in.. this kind of woring with fuse blocks & ground blocks amkes intalls and upgrades soo much easier and ti doesnt take much more time to do it righ the frist time. and prevent fires and equpiment damage .. and remember.. ify ou hook it up wrong. and let the magic blue smoke out of any electrical compemnet. .. it will enver work again.. somethign about the blue smoke staying inside of compoments makes them work
Old Dec 17, 2006 | 11:12 PM
how do you connect a fuse block?
Old Dec 17, 2006 | 11:13 PM
Neothin's Avatar
just run a wire to it.
i run a fused 10 awg wire to mine.
Old Dec 17, 2006 | 11:20 PM
SilyOtter's Avatar
connextino is easy.. it has a stud & a nut. so take yorue wi re crimp on a ring terminal. of appropriate si ze and screw it down. easy easy easy
Old Dec 17, 2006 | 11:26 PM
so the fuse block has slots for fuses? and all you do I hook up you accessories to it?
Old Dec 17, 2006 | 11:27 PM
SilyOtter's Avatar
yup has slots for a regular atc fuse. and little tabs that stick out the sides for each fuse. they take a regular femal spade termuinal. them ost common termial in teh world really.. just snaps on the tab and puta fuse in and bingo .. power!
Old Dec 17, 2006 | 11:32 PM
maybe you can help me do all this?
Old Dec 17, 2006 | 11:33 PM
SilyOtter's Avatar
since you're in san pedro.. i thik i might be able to.. this week is crazy. but ill send you a private message with my cell #
Old Dec 17, 2006 | 11:34 PM
Neothin's Avatar
if you check out my picture, you can see the fuses, main line comming in, and the spade terminals all connected
Old Dec 17, 2006 | 11:44 PM
if I have next weekend off ill try and make it not sure yet. I an drive there or we can meet somewhere.I just need to know what parts to buy. a good fuse block and wire and stuff
Old Dec 17, 2006 | 11:45 PM
SilyOtter's Avatar
if all u need is parts. ill borrow some from my shop. .. ill see what i can do
Old Dec 17, 2006 | 11:50 PM
I get payed wed so I can buy parts. just tell me how much it it
Old Dec 18, 2006 | 12:00 AM
SilyOtter's Avatar
ya no problem man!
Old Dec 18, 2006 | 04:58 AM
SilyOtter's Avatar
.. do it right hte first time and never look back
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
clickclickw00t
Feb 18, 2015 08:57 PM
corbmonster
Jan 24, 2015 05:22 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
dzcustom
22
Feb 14, 2006 10:58 PM
