S Techs and Camber Kits
Old Dec 28, 2006 | 02:39 AM
fsan619's Avatar
Default S Techs and Camber Kits
Okay, so I just purchased a set of S-Techs and I am wondering if anyone has any infomation on wheather or not camber kits are really neccessary. I have already done the research, and I was planning on buying the Hotchkis rear cK and the Ingals front cK. Is anyone else running their car w/o the cK on Stock stuts? Is this a common thing to do? Any problems with alignment w/o the cK?
Neothin's Avatar
i run stech's w/o any aftermarket camber adjustment pieces.
i'm in stock specs
Old Dec 28, 2006 | 02:42 AM
fsan619's Avatar
Thanks Neo... I am just trying to see where I do and don't need to spend the dough at - you know?
Old Dec 28, 2006 | 02:50 AM
Neothin's Avatar
well... even if you don't *need* it, it's still another thing you can say that you have to a car show judge
Old Dec 28, 2006 | 02:52 AM
fsan619's Avatar
This is true.
Old Dec 28, 2006 | 03:02 AM
tc-guy's Avatar
i have s-techs on my tc and at first i thought i was kool but i checked my tires recently and i noticed that the insides of my tires were jus a little bit more worn then the outside.
so i would say get the camber kit to be safe. when i change my tires imma get a camber kit for the front.
Old Dec 28, 2006 | 03:06 AM
fsan619's Avatar
tc, did you try and get an alignment after you installed the s-techs? If so, did the shop say it was alignable?
Old Dec 28, 2006 | 04:21 AM
tc-guy's Avatar
yea , i got an alignment and it was close to spec. maybe cause of potholes and bumps in the road it fell out of alignment. i will take it back to get an alignment when i take my front bumper kit off. it won't go on the rack the way it is now.
Old Dec 28, 2006 | 04:48 AM
jonnyHKboi's Avatar
been on s-techs for a almost a year now and never needed camber kit. alignment was done and was just inside of factory specs so technically does not need camber kit. i've had even waer on my tires. just keep the suspension aligned and ur golden.
Old Dec 28, 2006 | 04:51 AM
Control_Are's Avatar
i just had my s-techs installed on friday. before i went with those springs, i was worried about camber problems due to the extreme drop that come with the s-techs so i searched for topics about camber kits and found this thread:
https://www.scionlife.com/forums/viewtopic.php?t=153063
the whole thread is pretty informative but check the post by gortok.
as for my ride, i have super, slight negative camber in the rear but i plan on getting an alignment within 2 weeks or so..
Old Dec 28, 2006 | 03:33 PM
fsan619's Avatar
Hey, guys. Thanks for all the information - you have all been a great help! I will post some pics as soon as I have all the gear installed.....
jcraff3
Feb 20, 2015 11:41 PM
Alvie
Dec 12, 2014 05:04 AM
umnitza
Dec 1, 2014 06:26 PM
Mr_Magu
Jan 17, 2004 05:21 AM
randode
10
Dec 11, 2003 06:05 PM
