hitting the track .
Old Jan 2, 2007 | 10:41 PM
toyotaracer9's Avatar
Default hitting the track .
taking my GFs car to the track tom. night .
specs are:
homemade kit log manifold
garrett to4b s-trim turbo with .48 turbine
non-intercooled 6lbs running water/meth injection
1 gallon of toluene with 7 gallons of 93 octane
looking for 13.99 , do u think its possible ?
Old Jan 2, 2007 | 10:49 PM
j3st3r's Avatar
Music City Scions
Default Re: hitting the track .
specs are:
Get some pictures man.....and good luck!!!
Old Jan 2, 2007 | 11:47 PM
zer0's Avatar
My guess is mid 14s, with good traction 13s are possible
Old Jan 3, 2007 | 12:35 AM
XD40tC's Avatar
Have you run with that fuel mixture before?
Old Jan 3, 2007 | 01:02 AM
traction is usually good out there .
no I havent ran this fuel mix before , why do u ask ?
Old Jan 3, 2007 | 01:12 AM
BlKtC05's Avatar
how do you like the water/methyl? do you see any cons, all anyone talks about is how great it is...
Old Jan 3, 2007 | 01:58 AM
soros151's Avatar
watching, and good luck!
Old Jan 3, 2007 | 02:42 AM
I like it , the only issue I have is that I cant advance my timing , so it only acts as a cooler and not a way to run more timing .
Old Jan 3, 2007 | 02:49 AM
XD40tC's Avatar
Just wondering how that Toluene addition is going to run. Let me know how that goes ok?
Old Jan 3, 2007 | 03:49 AM
BlKtC05's Avatar
why dont you go with an fmic of a charge cooler?
Old Jan 3, 2007 | 12:46 PM
Prototype_xB's Avatar
Straight T4! Good job
Post up your slip when you're back
Old Jan 3, 2007 | 02:27 PM
sorry i didnt specify , it is a t3/t4 .48 a/r t3 turbine
the reason I didnt go FMIC is because this is my GFs car and dont want the complex design to keep me working on her car " I have my own turbo and s/c trucks to keep me busy"
I added the toluene to 9-10 gallons of 93 oct. so my octane rightnow is 95+ whatever the methanol is bumping it to . I am trying to keep the knock sensor from having to pull timing .
Old Jan 3, 2007 | 04:51 PM
soros151's Avatar
How hard is it to find toluene?
Old Jan 3, 2007 | 04:53 PM
^^ go to a paint supply store , its pretty expensive tho .
Old Jan 3, 2007 | 08:02 PM
oh well , test n tune is cancelled do to rain , I guess it will be next wed. and another 17 dollars of toluene .
Old Jan 5, 2007 | 01:42 AM
BlKtC05's Avatar
is the methyl good for a daily driver?
Old Jan 6, 2007 | 02:33 PM
TianaTC's Avatar
toluene mix for 103 octane is for every 3 gallons of 93 one gallonof toluene. it can be found at sherwin williams. what mix are you doing with the water methyl? what %? adding the water injection you could run more boost what are your afr's
Old Jan 6, 2007 | 08:52 PM
actually I think it would be 98 octane . I am running 35% methanol .
blktc05 , running methanol on a daily driver is good for a daily driver , i dont know exactly what u are tryin to campare it to though .
Old Jan 6, 2007 | 09:48 PM
BlKtC05's Avatar
well i know that you have to refill the resevour all the time and i wasnt sure if that was very cost effective. im compairing it to the pwr inline chargecooler. i really dont want an fmic and if i dont have to i dont want to have to plumb anything. i just need some cooling for my boost!
Old Jan 6, 2007 | 10:08 PM
well the PWR would definately be more efficient for cooling the charged air , but I am also using this as a supplemental fuel source . I go through a gallon of washerfluid once every 2.5 weeks which is about $1.50 . so it isnt very bad I dont think . plus it keeps the carbon buildup from being created in the engine .
