hitting the track .
taking my GFs car to the track tom. night .
specs are:
homemade kit log manifold
garrett to4b s-trim turbo with .48 turbine
non-intercooled 6lbs running water/meth injection
1 gallon of toluene with 7 gallons of 93 octane
looking for 13.99 , do u think its possible ?
specs are:
specs are:
specs are:
Originally Posted by BlKtC05
how do you like the water/methyl? do you see any cons, all anyone talks about is how great it is...
I like it , the only issue I have is that I cant advance my timing , so it only acts as a cooler and not a way to run more timing .
Originally Posted by Prototype_xB
Straight T4! Good job
Post up your slip when you're back
the reason I didnt go FMIC is because this is my GFs car and dont want the complex design to keep me working on her car " I have my own turbo and s/c trucks to keep me busy"
I added the toluene to 9-10 gallons of 93 oct. so my octane rightnow is 95+ whatever the methanol is bumping it to . I am trying to keep the knock sensor from having to pull timing .
toluene mix for 103 octane is for every 3 gallons of 93 one gallonof toluene. it can be found at sherwin williams. what mix are you doing with the water methyl? what %? adding the water injection you could run more boost what are your afr's
actually I think it would be 98 octane . I am running 35% methanol .
blktc05 , running methanol on a daily driver is good for a daily driver , i dont know exactly what u are tryin to campare it to though .
well i know that you have to refill the resevour all the time and i wasnt sure if that was very cost effective. im compairing it to the pwr inline chargecooler. i really dont want an fmic and if i dont have to i dont want to have to plumb anything. i just need some cooling for my boost!
well the PWR would definately be more efficient for cooling the charged air , but I am also using this as a supplemental fuel source . I go through a gallon of washerfluid once every 2.5 weeks which is about $1.50 . so it isnt very bad I dont think . plus it keeps the carbon buildup from being created in the engine .
