tC Service Manual Findings
Old Aug 13, 2004 | 01:34 PM
zoltiz's Avatar
N.G.S.O.
Default tC Service Manual Findings
How about we put interesting stuff from the service manual in this thread.
Things I found so far (after 5 minutes of reading):
The funny looking "extra filter" in our airbox (the on in the top part of the box) is a charcoal filter that's meant to reduce evaporative emissions when the car is stopped. In other words it abosrbs unburnt fuel that oozes from the throttle body when you shut off the car. That's like 5hp right there...
Our muffler has a 2-way valve that opens up at higher RPM to help with peak hp. Not bad for an econocoupe...
Old Aug 13, 2004 | 02:13 PM
KnowledgePerformance's Avatar
There was only a one (1) HP gain (no change in Torque) from removing both of the filters vs. w/ the filters. I think the OEM filters are quite efficient.
Old Aug 13, 2004 | 02:20 PM
zoltiz's Avatar
N.G.S.O.
Both filters as in charcoal and paper? Ran with no filter at all?
That strikes me as odd - cause the stock airfilter is the same as the one used on a much smaller 1ZZ engine. And there was still 1HP gain - 1HP is well into dyno error margin...
Old Aug 13, 2004 | 11:31 PM
Moltar's Avatar
Could it be that the stock airbox is actually very restrictive? Did you try dynoing the car with the airbox completly removed?
Old Aug 13, 2004 | 11:36 PM
JT_Scion's Avatar
Dyno'ing without the airbox wouldn't work because the airbox has the MAF sensor on it.. My celica wouldn't even start if i had the MAF sensor out of the airbox.
Old Aug 13, 2004 | 11:41 PM
Moltar's Avatar
Ahh ok. Surely there is a way to remove MAF sensor from the airbox though?
Old Aug 14, 2004 | 12:33 AM
JT_Scion's Avatar
Yea, it screws into the airbox with 2 screws so its real easy to pull out.. but all of your idle control is based on readings from that sensor so its definately got to be drawing air thru it either in the airbox or on an intake pipe (ie. cai) to keep your car running.
Old Aug 18, 2004 | 02:48 AM
cf_engineering's Avatar
Our CAI has a built-in adapter to screw on the MAF sensor. We are currently prototyping and hope to have it out in the next month or so
Thanks,
Clift
kleecker
9
Aug 2, 2022 05:00 AM
kleecker
Feb 12, 2015 11:02 PM
kleecker
Jan 1, 2015 07:34 PM
kleecker
Dec 31, 2014 09:42 AM
Kodokan_4
Jun 26, 2004 07:23 AM
