wilwood big brake kit
Old Jan 16, 2007 | 05:50 PM
iqbokc's Avatar
Default wilwood big brake kit
okay, have another question for my scion brothers and sisters. i have the wilwood bbk 4 piston. and really i dont feel any improvement. so i would like to hear your opinion about them. tell me what kind of brakes u r using! how u like them. and i am running with 235/45/17. please put your 2 cent on this one. thanks again.
Old Jan 16, 2007 | 05:57 PM
2fast4you's Avatar
Team ScionTific
Big brakes don't always equal better braking.
Old Jan 16, 2007 | 06:19 PM
trdtcpr's Avatar
I'm using drilled/slotted OEM sized rotors with OEM brake pads and the OEM brake lines and i felt the diference not much but surely there was a diference.
and what 2fast4you is very true!
Old Jan 16, 2007 | 06:46 PM
riboflavin's Avatar
BBK is for show IMO, yeah they may improve lil bit of performance, but I think changing to better brake pad will be better.
Old Jan 16, 2007 | 06:56 PM
Mightygnu's Avatar
it helps a little, but yes, i agree that it is more for show.
Old Jan 16, 2007 | 09:28 PM
nodsetse's Avatar
In order to notice the improvment, you have to USE the bbk. I mean for an extended period, such that they're hot for a long time, such as at a track. That's when you'll notice the difference, when stock brakes begin to fade, the bbk won't.
BBK may not stop shorter than stock when cold, but certainly will when they're both exceptionally hot.
Old Jan 17, 2007 | 06:55 AM
captainlaziness's Avatar
Default Re: wilwood big brake kit
What pads and what tires? Those two things will make the biggest difference in braking power.
Old Jan 17, 2007 | 07:20 AM
TinmanTC's Avatar
Old Jan 17, 2007 | 07:25 AM
Old Jan 17, 2007 | 08:04 AM
iqbokc's Avatar
using the wilwood big brake kit, the pads the came along with the kit. and running on bridgestones potenza reo50a pole position. 235/45/17 all four and i know they are summer tires and i'm only apply to the summer for my question.
Old Jan 19, 2007 | 07:09 PM
2redgerm6's Avatar
your tires are a bigger aspect ratio than they are supposed to be you should be using a 235/40-17 (i think thats the size). using larger tires will increase you braking distance. bbk are for track use. they are for better heat disapation more than anything else. try braking from 100 mph 15 times in a row with regular brakes then with bbk and tell us if you notice a difference haha.
Old Apr 19, 2008 | 12:53 AM
SuperSlowTC's Avatar
i feel a big difference with the brakes. maybe its because i wasnt able to stop well with the big wheels that i have. but after the brake kit i felt a big difference.
Old Apr 19, 2008 | 01:00 AM
Garage1217's Avatar
I noticed one heck of a difference, You would have to be numb to not notice anything especially with grippy tires. If you have any moles on your face, come for a ride my my tC, bet they will be stuck on the windsheild in a hurry haha.
Lets see some pics of your wilwood kit on your car
Old Apr 19, 2008 | 01:04 AM
1_kLEan_tC's Avatar
Can't wait until I get my kit.....
Old Apr 19, 2008 | 02:35 AM
WendysOrBust's Avatar
I'd really only think about getting a bbk if I was driving on seriously soft tires. Other wise its a waste. 615's, Rs2's, Re01r's and if your mad baller then some Toyo R888's.
Driving with a bbk while rolling on the all seasons is like adding 2+(-2)
Old Apr 22, 2008 | 08:42 PM
davedavetC's Avatar
thank god for sumer tires
Old Apr 22, 2008 | 09:46 PM
Stardust's Avatar
LOL
Old Apr 23, 2008 | 03:41 AM
2fast4you's Avatar
Team ScionTific
I finally installed my Wilwood BBK... no difference during normal street driving.
However... punch it up to 90+ mph and pray you don't have any loose items under hard braking. Like others have said: BBKs are a total waste if you don't have sticky tires. And I will continue to say you don't need BBKs unless you track your car. I did a "Stage 2" upgrade on my brakes last year and it was a great improvement on the street... until I did a track day last year and had to step up.
The specs:
Lolipop Blue Wilwood 4-piston BBK
Wilwood GT-series slotted rotors
Carbotech AX6 (Front)
Carbotech XP8 (Rear)
Stainless lines all around
Motul RBF600 fluid
Falken Azenis RT-615
Watch this thread for pics!
Old Apr 23, 2008 | 03:51 AM
wow, I really like your setup, I hear nothing but good thing from the carbotech pads. Pics ASAP!
Old Apr 23, 2008 | 04:35 AM
Garage1217's Avatar
The specs:
Motul RBF600 fluid
Agreed, I run almost the exact same setup as you, same tires and all except I run powerslot rears.
