Power wire to battery terminal
Old Jan 22, 2007 | 12:21 AM
Zebman's Avatar
Default Power wire to battery terminal
I'm completely stumped here. How do I attach the battery clamp to the positive battery post while retaining the connection of the positive wire? There's absolutely no room on it. I don't know how to do this. Any close-up pics of how all of you with systems did this?
My clamp only has two 4awg inputs, one is for my power wire.
Pictures needed if necessary. Thanks for any responses.
Old Jan 22, 2007 | 05:12 AM
ADRdesignCo's Avatar
you loosen the screw and attach the one for the amp on it. at least thats what i did.
Old Jan 22, 2007 | 06:05 PM
Zebman's Avatar
I'll probably end up doing that. Do you think you're getting a sufficient connection with a ring terminal?
Old Jan 22, 2007 | 10:54 PM
make sure its right on it. make sure its not touching the negative lol. and as long as its crimped on to the wire well enough, it should be ok.
Old Jan 23, 2007 | 01:09 AM
Zebman's Avatar
Thanks for the post, I ended up doing this. The terminal is pretty thick, so I crimped it with a heavy-duty clamp. That thing is going nowhere. I plan on upgrading to 0awg when I add my Nine.2x, so i'm going to try to find a better connection by then. Probably a Yellow Top battery and a the Topper for it.
missing_image
Feb 7, 2015 07:18 PM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
randode
44
Jun 29, 2004 04:19 PM
crystaljukebox_com
Feb 5, 2004 05:53 AM
