Long wheel studs
Old Jan 25, 2007 | 01:28 AM
BlackTop's Avatar
Default Long wheel studs
Does anyone know where you can find longer wheel studs for an Xb? I got the BBist fender flares but my stock studs are to short for the spacer i need to push my wheels out to the edge of the flares.
Old Jan 25, 2007 | 01:09 PM
TerribleTed's Avatar
Most places that sell spacers also sell extended studs. My Ichiba spacers had them included in the spacer kit (in a 5MM spacer kit they had extended studs, tho I see no reason to use them with only 5MM spacer...plenty of stud left still with these...bigger spacer than 5MM then studs would be needed I am sure).
Old Jan 25, 2007 | 09:39 PM
YELOSUB's Avatar
Wagonistas
Im runnning a 10mm shim that goes behind the rear hub assembly and I also have a 5mm spacer that goes over the studs and I used the stock wheel studs...There was plenty of thread and so far my rear wheels haven't fallen off...lol
Old Jan 25, 2007 | 09:45 PM
smokeydog001's Avatar
I'd recommend the 20mm rear spacers from One Ton Garage. You don't have to fool with changing studs.
http://www.onetongarage.com/products...him/index.html
Old Jan 26, 2007 | 01:10 PM
Nice!! I stand corrected I guess my eyeball eyeballed the studs shorter than they are!!
Old Jan 26, 2007 | 06:57 PM
Subcompact Culture's Avatar
I have H&R TRAK 15mm spacers on the rear of my xB and they came with extended lugs.
Old Aug 20, 2008 | 10:05 PM
ryuji16's Avatar
can someone confirm this for me? i have a pair of 5mm spacers laying around and ive been debating with myself whether i need extended studs for them. would it be safe on a daily driver?
Old Aug 21, 2008 | 12:14 AM
I indeed have 5MM spacers on the back of my first gen xB. There is plenty of engagement between the lugnut and stud for safety. If you read above it seems that spacers up to 20MM might leave enough stud for safe engagement of the lug nuts, but 5MM is no problem at all for sure.
Old Aug 21, 2008 | 02:53 AM
YELOSUB's Avatar
Wagonistas
Yes indeed, he speaks the truth...I had 5MM spacers for awhile without extended lugs and there is PLENTY of thread engagement...
Old Aug 21, 2008 | 03:32 AM
ryuji16's Avatar
good to know. thanks guys
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
Deves
Feb 8, 2015 11:37 PM
BManAmericae
Jan 18, 2015 12:17 PM
Slopoke21m
54
Apr 23, 2007 12:25 AM
Docofmind
Nov 11, 2003 07:09 PM
