tire pressure
Old Jan 30, 2007 | 09:08 PM
jo53mo's Avatar
Default tire pressure
Just purchased 2007 TC with the standard 17 inch tires. Should i use the recommened psi from the door panel which is 32 front 29 rear or can i go higher since i live in NYC and some of the roads are really in bad shape.
Thanks, Joe
Old Jan 30, 2007 | 09:21 PM
nodsetse's Avatar
Sure you can run higher pressures. I've had mine at 36F/32R for a year, no probs at all.
This gives you slightly better fuel economy and improved cornering performance.
When I rotated the tires at 5k miles, the treadwear was even, so no worries.
Old Jan 30, 2007 | 09:37 PM
KINGxOFxSKA's Avatar
Unique Scionikz
Stick with the factory recommended specs please. If a vehicle's tires are overinflated, they could be damaged more easily when encountering potholes or debris in the road, as well as experience irregular tread wear.
Old Jan 30, 2007 | 09:48 PM
Fast_Eddie's Avatar
Speaking of tire pressure.......are there different specs for the RS1since they come with 18" wheels?
Old Jan 30, 2007 | 09:53 PM
Unique Scionikz
the factory tire pressure for your tires will be located on the drivers side door jam
lateralus894's Avatar
for the rs1 i run 36 up front and 34 in the back. grips really nice and even with the snow around here they grab great(toyo's are pretty bald and i havent slid yet.
Old Jan 30, 2007 | 10:05 PM
CuRiOuSfIsH's Avatar
I would also stick w/ factory specs......................
but didnt. 35F/32R. You will feel the bumps a bit more though. When I 1st got the tC, I was wondering why the ride felt so soft.
Old Jan 30, 2007 | 10:07 PM
TheQuietThings's Avatar
if you pump the pressure up on the tires, the tread will wear out faster, and there will be a slightly higher chance of blowing a tire out on a pothole.
If you dont inflate the tires enough, you will get horrible gas mileage.
i also live in NYC, and i would recommend you keep the tire pressure 32/29 on stock tires.
Old Jan 31, 2007 | 09:37 PM
Fast_Eddie's Avatar
Thanks, I know where the tire pressure information is, but part of my mods on my '05 tC was a change to the Enkei Super 7 18" wheels, and I wondered if there was a different pressure guide inside the RS1 door jam since the are delivered with the Enkei 18" wheels.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
kingofthecrate
Jan 21, 2015 09:28 PM
JDMxB
23
Feb 26, 2004 06:16 AM
Strader
Oct 12, 2003 11:46 PM
