Blah wheel controlz...
Old Feb 2, 2007 | 05:24 AM
XD40tC's Avatar
Default Blah wheel controlz...
Ok I searched but couldnt find my answer... how the heck do you pop off the steering wheel radio control shrouds? I pry and pry but all I get is a loud beeeeeeeeeeep!
Old Feb 2, 2007 | 05:28 AM
SquallLHeart's Avatar
you need to take apart the steering wheel..
two T30 torx bits... move airbag... then a phillips head screwdriver... and wire cutter to snip the zip tie.
you know there's a tech article on it right?
https://www.scionlife.com/forums/viewtopic.php?t=91321
Neothin's Avatar
around the backside of the steering wheel... there's 2 holes. one ont eh left, and one on the right. inside there's a t30 torx head screw. loosen these 2 bolts.
once loosened, pull the airbag/horn assembly towards you gently and let it rest.
a phillips head screw will no be exposed, 1 for each steering wheel piece. remove the screw and now you can pull the piece towards you and remove it from the steering wheel.
check the tech section for the steering wheel led swap DIY. it has those same directions + pictures.
Old Feb 2, 2007 | 05:30 AM
found it.. linked it...
lock.
evolving_machine
Oct 21, 2023 01:16 PM
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
EcoxA
Mar 18, 2015 03:45 PM
GoodVibes
Mar 3, 2015 09:47 PM
DibujoB
51
Jul 15, 2007 01:01 PM
