Speaker wiring help
Old Feb 15, 2007 | 07:17 PM
sciontc03's Avatar
Default Speaker wiring help
I have 2 amps, 1 for my subs and 1 for my mids and highs. My question is how to wire the front door speakers and tweeters and the rear speakers to the amp. I can figure out how to wire my subs to the sub amp, but I need help with wiring a cap in the system. Also, all of thr LEDS on my custom box need power also. How do I hook up the + and - from the LED wires. I already wired all the LED's together into one + and one -. Please help me out with this confusion.
Thanks
Old Feb 15, 2007 | 11:59 PM
superiorauto's Avatar
Default Re: Speaker wiring help
Thanks
to wire the door and rear speakers you first need to run rca cables to the amp then run conductor wire (we use a 9 wire cable and the 9th wire we use for the remote turn on ) from the amp up to the factory wiring harness and make your connections there so you wont need to run new wire to each speaker.
for the cap you can run your power wire from the battery straight to the + terminal on the cap first , then branch off of the cap with the other 2 wires for your amp to save time and wire when you run your ground for your cap do the thing as you did with the power wires by branching off the - terminal to run the ground wire to the amp and dont forget to run the - wire from the cap to a good ground spot on the vechile
for your leds you can get your power from the remote wire and the ground from the amp
hope this helps
jonny_b
Scion tC 1G ICE & Interior
May 2, 2015 01:45 PM
dltjdgns66
Apr 15, 2015 07:59 AM
clickclickw00t
Feb 18, 2015 08:57 PM
cwong1001
Dec 3, 2014 03:30 AM
vpkb
12
Oct 8, 2003 04:17 AM
