Tail Light Replacement
Old Feb 27, 2007 | 01:46 PM
posjetta96's Avatar
The Family
Default Tail Light Replacement
Could anyone tell me the process of changing out my driver side tail light on my tC. I was working on it last night and just couldn't get the thing out. Any help would be very much appreciated.
Old Feb 27, 2007 | 03:56 PM
Amoxaphobic's Avatar
I will be making a DIY about this within the next couple of days, but I realize that that might not be soon enough for you.
I removed my tail lights last weekend and found that I had to remove the bumper. There might be a way to do it without removing the bumper, but I don't know what it is because there are clips on the bottom of the light that hold the bumper.
The bumper is pretty easy to remove though. There are 2 screws in the rear wheel wells (1 in each), 2 screws on top of the bumper (under the trunk hatch lid), and 3 plastic "rivets" on the bottom of the bumper. All of these must be removed.
Once all of those are out, firmly tug on each side of the bumper to "unsnap" or unclip it from the car... once both sides are unclipped, it should come right off.
The tail lights will the need to be unscrewed. From the inside of the trunk, there are two covers that cover up that back of the tail light. Remove these to access the tail light. There are 3 10mm nut/bolt (kind of like a triangle pattern) on the back... one of them has a white plastic holder (hold the wire for the lights) and one of these bolts is longer than 3". Because of this long ___ bolt, a deep socket or a open end / box end wrench is needed. After these nuts are removed, unplug the light.
The light should now be free, but you might need to give a good tug on the light because of some more clips that hold the light in place. Pull straight out and you should be fine.
Voila!
Like I said, I will be doing a write up on this, so if you can wait for the pics, it might help more. But this should do just fine too. Hope this helps!
Old Feb 27, 2007 | 05:57 PM
s44life's Avatar
actually after I had taken the bumber halfway off I still had to pull the lights up then out. They're also attached to the bumper.
I don't see why the 3 screws weren't enough for Scion.
Old Feb 27, 2007 | 06:07 PM
SquallLHeart's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=119867
same process
xBSciontist
Jun 18, 2019 03:06 PM
TheTripleC
Jan 4, 2015 06:46 PM
mrbadass03
24
Apr 21, 2004 02:17 AM
Slopoke21m
Oct 2, 2003 04:59 AM
randode
16
Oct 1, 2003 12:40 AM
