Rubber Preservative
Old Mar 1, 2007 | 07:52 PM
Inky's Avatar
Default Rubber Preservative
Anyone using anything to preserve the various rubber pieces (aside from the tires) on your Scion? If so, what's good? I've heard good things about Zymol.
(Sorry if this has been discussed before. I searched but came up with over 3,600 results, which are too many to sort through.)
Old Mar 1, 2007 | 08:00 PM
Neothin's Avatar
if you can find it, klasse VLRP works wonders.
Old Mar 1, 2007 | 11:50 PM
ESEMRFOZZ13's Avatar
spray silicone works to preserve weather strip and bushings etc.. it keeps them from dry rotting and water proofs, if thats what your asking or are you going for shine. zymol has car kits that go up to aroud $450, they got some high end products as well as lower priced ones. i like thier products
Old Mar 2, 2007 | 01:11 AM
Inky's Avatar
Thanks for the replies. I want to avoid dry rot. I'm not too worried about shine, though it tends to be a nice by-product.
Old Mar 2, 2007 | 01:25 AM
yeah thats what the dealer is suposed to do when they change your oil is lube the chasis, but we all know they dont do much of anything.
Old Mar 2, 2007 | 01:33 AM
Max's Avatar
Max
Um. Silicones will actually work to aide the dry-rotting process if not applied continually. Once you start, you have to keep using it or you will dry out the stuff you're trying to protect.
Old Mar 2, 2007 | 02:16 AM
Tomas's Avatar
Admin Emeritus
Bob is the Oil Guy thread...
When I was in the USAF we used (IIRC) Mil-P-11520F. It worked well, but I suspect there should be better stuff out by now.
Tom
Old Mar 2, 2007 | 02:44 AM
are you well informed on this, i got that info from a car tech but if you know something thats well informing or works better then im all ears
Old Mar 2, 2007 | 04:51 PM
nyr197's Avatar
303 aerospace protectant. You can pick it up at any boat/marine shop, or order through NAPA.
http://www.303products.com/main.php
This stuff dominates.
Old Mar 3, 2007 | 12:22 AM
Max's Avatar
Max
I am not an expert on silicone, I just know what I read online. Here is one such article:
http://www.meguiarsonline.com/forums...hp/t-7368.html
There are good and bad silicones. I'd just rather avoid them all.
Old Mar 3, 2007 | 12:40 AM
paul34's Avatar
+1. Doesn't last the longest on exterior trim, but it does its job well enough.
Old Mar 3, 2007 | 04:24 PM
i only used it for my suspension, so the sun doesn't effect it. all input is good so keep your thoughts rolling.
Bimfi
Sep 4, 2015 08:15 PM
AMS13
Aug 20, 2015 07:26 PM
Subaru86
Jul 31, 2015 04:00 AM
Wrencher
Jul 29, 2015 01:38 PM
LVXB
Apr 26, 2004 01:20 AM
