I need a definitive answer (drag wheels)
Old Mar 7, 2007 | 05:14 PM
dcmcelreath's Avatar
Default I need a definitive answer (drag wheels)
Hello all, after searching I still haven't found out what I needed to know for sure.
I read that with the Drag DR20's you need a spacer front and rear. What I didnt find out was if this is true on the new dr20's that came out for the xB, xa, and miata. The new ones are a 15x7.5 w/ a 38 mm offset
I already have the OTG spacer in the rear, but I am wondering about the front.
Thanks in advance.
Dustin
Old Mar 7, 2007 | 06:36 PM
Subcompact Culture's Avatar
As long as the offset is under 40mm you will NOT need a spacer. Keep in mind that 38mm is the stock offset.
Old Mar 7, 2007 | 08:30 PM
The issue that I read about was clearance of the caliper bracket. So does the 38mm offset solve this issue also?
Great info to know too btw, thank you
Dustin
Old Mar 8, 2007 | 01:28 AM
A +38 will be no problem at all. It's when you start getting into 42, and up that you'll start to have a problem.
Old Mar 13, 2007 | 08:33 PM
StealthBox's Avatar
I belive that some 06.5 xB's had a problem with clearing the calipers.
B-
Old Mar 18, 2007 | 06:54 PM
Rowdy_xB's Avatar
Plz help me out here, the rims im wanting to get have an offset of 42. Yall are saying you run into problems with 42. What kind of problem are you talking about?
evolving_machine
Oct 21, 2023 01:16 PM
XB06
May 30, 2015 02:42 AM
STCxB
11
Jan 9, 2015 04:30 PM
DR_xB
Jul 20, 2004 08:31 PM
JDMxB
13
Dec 23, 2003 04:23 AM
