18 x 8 with H techs?
Old Mar 8, 2007 | 07:07 AM
Jiggaman's Avatar
Big Sky Scion
Default 18 x 8 with H techs?
will a set of 18x8 wheels fit with tein htechs on it?
i could also go with 18x7.5 what does everyone think?
thanks!
Old Mar 8, 2007 | 02:29 PM
Guru's Avatar
What offset?
Old Mar 8, 2007 | 02:46 PM
JQ's Avatar
JQ
these questions come up all the time. The width of the wheel is important, but if you are trying to find out if you are going to rub the offset is what will determine that. If you are going to run an 18 x 8 +38 for example that will fit fine on even s-tech. Where as an
18 x 8 +45 will fit but might rub at times. Where as an 18 x 8 +32 would be the same as stock.
Hope this helps
Old Mar 8, 2007 | 02:51 PM
mitchelltc1's Avatar
It's all about the offset, but are you sure about that JQ? I thought a higher offset allowed more room for a wider tire. My lack of knowledge is making me nevous about buying new wheels...
Old Mar 8, 2007 | 04:37 PM
Hat_Trick_Hokie's Avatar
A higher offset (something like 45mm with an 8" rim) will give more clearance to the fender. However, having a larger offset you also have to think about the inside of the wheel well (to struts/spring) because you don't want the tire rubbing on thoes either.
Old Mar 8, 2007 | 05:35 PM
Rabid_Lemming's Avatar
Hope this helps
I must have been confused with what I'd read....I thought you wanted to stay close to a stock offset? I was looking at an 18x8 with a 35mm offset. I was going to wrap it in 225/40/18 tires, but I scrapped the idea because I thought it would rub the fender from jutting out another inch on the wheel alone, not counting the sidewall of the tire....does this mean I can still get this setup?
Old Mar 8, 2007 | 05:39 PM
JQ's Avatar
JQ
Here is a good tool to help determine the inner and out changes.
http://www.1010tires.com/WheelOffsetCalculator.asp
just enter the stock wheel (17 x 7 +45) and then what the rim you are intersted in and hit "calculate"
And you are right I just worded the above post backwards.... sorry.
+45 13mm less inner, +38 6mm less, and +32 same inner.
Old Mar 8, 2007 | 05:49 PM
great tool, thanks!
Old Mar 8, 2007 | 06:02 PM
JQ's Avatar
JQ
Hope this helps
yes you should be able to get an 18 x 8 +35. This would result in the inner clearence being 3 mm less and the outer being 23mm extended which is roughly .90 of an inch. Now this should fit on most spring setups....what are you running?
Old Mar 8, 2007 | 06:07 PM
Hope this helps
I'm on H techs as well.
Old Mar 8, 2007 | 06:34 PM
JQ's Avatar
JQ
Rabid you'll be all set with that set up!
Old Mar 8, 2007 | 06:46 PM
topcivic1995's Avatar
look i have s tech springs on my car and i have 19x8 with a 38 offset car is set up clean go to my pictures and look
Old Mar 8, 2007 | 07:36 PM
Sweet, even with the tire? I'm thinking a 225/40/18....
Old Mar 8, 2007 | 08:07 PM
JQ's Avatar
JQ
Yea even w/ that tire...
post pics when ya gettem!
Old Mar 8, 2007 | 09:36 PM
Jiggaman's Avatar
Big Sky Scion
it is 18 by 8 with a 40mm offset.
fit on h techs?
Old Mar 8, 2007 | 10:24 PM
JQ's Avatar
JQ
Yes
8mm less inner clearance and extended an extra 18mm. This will fit no problem with 225/44 tires
Old Mar 13, 2007 | 04:23 AM
Jiggaman's Avatar
Big Sky Scion
1 set 18x8 Konig Unknown 5x100 for tC
mounting and balancing
1 set 225/40/18 Falken Ziex512
20pcs gorilla lug nuts w/key for tC
one last check! this is the final invoice, and will be on H techs? better safe then sorry!
Old Mar 13, 2007 | 04:29 AM
My new wheels should be here by the 14th...jiqqaman, you mind if I post some pics here for you guys to see when I mount them in?
Old Mar 13, 2007 | 05:31 AM
Jiggaman's Avatar
Big Sky Scion
hellz yeah! post em up!
Old Mar 13, 2007 | 05:55 AM
1_kLEan_tC's Avatar
[quote="JQ"]these questions come up all the time. The width of the wheel is important, but if you are trying to find out if you are going to rub the offset is what will determine that. If you are going to run an 18 x 8 +38 for example that will fit fine on even s-tech. Where as an
Hope this helps[/quote
So will a 32 offset work with no problems
