what springs work for this wheel?
Old Mar 8, 2007 | 03:09 PM
fatboitan's Avatar
Default what springs work for this wheel?
http://www.tireandwheeldeals.com/whe...e=423&finish=3
i wanted the 18x7 so what springs fit? i was thinking H-tech but not sure
Old Mar 8, 2007 | 03:10 PM
fatboitan's Avatar
and also what tire size would work...im thinking of getting toyo proxes 4
Old Mar 8, 2007 | 03:37 PM
sddykstr's Avatar
Basically any drop will work on 18's I am going with Hotchkis, looks really clean. H techs will look good too.
Old Mar 8, 2007 | 03:48 PM
fatboitan's Avatar
also i was going to add the front rs1 lip so is that going to cause the car to be lower? cause i dont want a drop that can scratch the lip when i get it so will H-tech, s-tech, or hotchkis be better?
Old Mar 8, 2007 | 03:53 PM
sddykstr's Avatar
I'd go Hotchkis. S tech will be really low, Neothin has s techs with the RS1 I think, so you could ask him. H techs or Hotchkis would looks great, I personally like Hotchkis.
Old Mar 8, 2007 | 04:00 PM
fatboitan's Avatar
which is cheaper? hotchkis or h techs
fatboitan's Avatar
cheaper but also good quality
Old Mar 9, 2007 | 02:49 AM
fatboitan's Avatar
anyone?
Old Mar 9, 2007 | 09:53 AM
Otocan's Avatar
they're both about a hundred to a hundred and fifty bucks, take your pick, google is your friend, you know.
also, Proxes are good tires, but for the price you'd be better off with Falken Azenis RT-615's or
Hankook Ventus R-S2's in 225/40/18
keep in mind neither of the tires I mentioned are to be used in the snow, but you shouldn't be using all-seasons in the snow anyways, snow is for snow tires.
Old Mar 9, 2007 | 09:54 AM
Otocan's Avatar
I just noticed you're in Texas, so I don't think snow is an issue, but I could be wrong. If that's the case, don't get the proxes, you're always losing something when you have an all-around tire that can at least bite a bit in the snow too, and when it comes to tires, I don't do tradeoffs, that's what they make purpose-built tires for.
Old Mar 9, 2007 | 02:51 PM
fatboitan's Avatar
so what tires are good for a city that is mostly hot,humid, and rain, and in the winter its just cold around 40 degree but no snow maybe a little ice and that is just like every 4 years?
Old Mar 9, 2007 | 04:53 PM
Otocan's Avatar
ventus RS-2's are better in the rain. If you want to spend some more money for rain-oriented tires (if you get a LOT of rain, like in Florida) you could look at Goodyear Eagle F1 GSD3's which run about $200 each depending on the size. I like my money, so I'd go with Hankook.
if it ain't studded, no tire helps on ice.
Old Mar 9, 2007 | 05:11 PM
fatboitan's Avatar
i think ima just stick with the proxes because i dont want to spend alot of money on tires when most of the time its just hot weather in houston
Old Mar 10, 2007 | 03:37 AM
Otocan's Avatar
ok, that makes absolutely no sense at all, but whatever, it's your traction that will suffer.
you don't need an all-season tire. Proxes4 are $156 each and are an all-season tire. RT-615s are $127 each and are leagues above the proxes4 in every respect except you can't use them in the snow. Hankook Ventus RS-2's have a higher MSRP than either of these tires, but can be found online for as much or less than the Proxes4.
Old Mar 11, 2007 | 07:11 PM
fatboitan's Avatar
well i went to tirerack and the proxes 4 were cheaper by like $15 per tire
Beesh
Jan 9, 2015 06:30 PM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
CAtC12
Dec 23, 2014 04:44 PM
minter66
Dec 15, 2014 01:45 PM
ScionVan
11
Oct 23, 2003 05:51 PM
