Speaker suggestions?
Old Mar 19, 2007 | 12:42 AM
jpauletteUSAF's Avatar
Default Speaker suggestions?
Hola, everyone. I'm going to be replacing all six speakers in my car, and adding a subwoofer. I already know I want an eD enclosure, but what should I get for speakers? If it helps any, I listen to punk/metal 99% of the time and I've already got a Panasonic MXE head unit. Can any stereo gurus out there help me?
Old Mar 19, 2007 | 03:39 AM
mom2boysdadsxb's Avatar
what is your budget? I would spend the majority of my funds on the front stage.There are many good passive 3 way systems that will fit easily.
Old Mar 19, 2007 | 11:03 AM
dougalast's Avatar
The eDi 6500s sound really nice. I have them for my front stage and couldn't be happier.
They don't offer anything for the rear though.
Old Mar 21, 2007 | 08:01 AM
coregmrconman's Avatar
Memphis...
Old Mar 21, 2007 | 10:47 AM
Memphis? Eh?
Old Mar 21, 2007 | 10:50 AM
I don't really have a budget. I'm not buying all of this at once, so if I have to piece it together to make it perfect, that's cool with me.
Old Mar 21, 2007 | 11:16 AM
dugzilla's Avatar
I'm partial to Alpine, but from what I hear the ED stuff is really good.
Old Mar 21, 2007 | 01:29 PM
mfenske's Avatar
www.diymobileaudio.com Tons of suggestions there. You can do it better and do it cheaper. The Dayton reference line from www.partsexpress.com seems to be pretty popular and you should be able to fit an 8" woofer in the doors of the xB without too much hassle. Add a decent tweeter in the dash and you'd have a pretty nice setup. Personally, I'm partial to the old school Boston Acoustics "Rally" components. If you ever happen to see either the RC41, RC51, or RC61's on Ebay in good shape scoop them up as you'd be hard pressed to find a better sounding speaker for the money.
Old Mar 21, 2007 | 09:31 PM
Winter's Avatar
JBL
i say stick with a reputable company really. Memphis is pretty good, i personaly like JBL and thier GTi series. i've got alot of experience with thier live stuff so i gives me more then enough comfert to go for JBL's automotive market.
Old Mar 21, 2007 | 09:44 PM
I think Memphis has the best Mids I have heard. I listen to Alt Rock and it sounds amazing.
Old Mar 22, 2007 | 04:03 AM
How much are you willing to spend on the speakers for the front stage?
Old Mar 22, 2007 | 10:39 AM
front stage, hmm.... let's say $400 installed for the front, and I wouldn't mind upgraded wires :-D
Old Mar 22, 2007 | 05:51 PM
Winter's Avatar
@jpaulettelUSAF - curious, your taste of tunes, i hit up your myspace and heard you kick a$$ song on there and was wondering if that was what you normaly listen to most of the time?
fast bass kick attacks may require looking for specific specs on the subs. if you want to hear the actual kicks and not just a rumble, it would be wise to look for two main things.
all speakers have TS specs, if you can get your hands on the TS specs for what ever subs you are looking at, may i sugjest looking at the BL and QTS. BL is the magnet and voice coil motor strength and QTS is how acurate the cone can react to the attack. general rule of thumb, the higher the BL the better while the lower the QTS the better. when you've found some subs that interest you, contact the maker of them and see about getting the TS spec from them. just a sugjestion though if you'd like to go that far.
Old Mar 22, 2007 | 11:07 PM
I usually listen to things similar to that. Lots of double bass, screaming, you name it. Look What I Did is one of my favorite bands, as of right now.
Thanks for this info. I'm hoping to not have to get super-technical with the speaker specs, but I will if it's going to be the best for the kind of music I listen to.
Old Mar 23, 2007 | 02:28 PM
Dude, your system must sound awesome.Why don't you post some pictures of it?
Old Mar 23, 2007 | 07:23 PM
Winter's Avatar
i haven't been able to to get my system togethere yet. my experience comes from the design and development side used for live settups and studio monitoring. TS specs are always nice to have handy when building a system strickly meant for a personal listen style. just throughing a system togethere could be a nightmare sometimes when you're are looking for that specific style and not taking the technical side into play cause be a real headache and can burn a nastey hole in your pocket when trying to take parts out and put new parts in looking for that right tune when you could settup a system strickly meant for you'r style and tune it based on what the hairs in your ears feel is right OR do a flat tone RTA tuning where everything is "HiFi" tuned from 20hz-18khz so that theres no weak points.
but like i said though, if ya need any help, just send me the make and model and i can get ahold of the TS specs *9 times out of 10 atleast* and let ya know if it's acceptable for quality attacks.
car subs though have a much heavier cone structure then whats normaly used for live and studio systems so these stats that i would be looking for are much lower/higher *BL/QTS* then what you would find in live or studio applications so what i'll be looking for is fast attack between 20-70/80hz while what i would look for normaly in live or studio would be 35/40-150hz. lighter the cone and the stronger the magnet structure, the faster and more accurate the attack is BUT capability of handeling VERY low tone below 35/40hz becomes very limited. to enhance extreme lows, the cone must be heavier fortified and capable of handeling the large movement attacks but in doing this, you loose the accurate high end capability because now the cone is too heavy to move so quickly. also know that bass is omni directional upto around 70/80hz so subwoofers for automotive audio don't need to be accurate past that point.
Old Mar 24, 2007 | 08:54 PM
Thanks for the much-appreciated tech data. However, I decided to just go with the eDi 6000s v.2 because my friend cranked up some Hatebreed in his car with that system and I'm pretty sure I got a boner.
Now, any suggestions for the rear stage? I'm thinking about doing maybe two 8" subs to replace the back speakers
Old Mar 25, 2007 | 12:03 AM
bryman31's Avatar
if you want true studio sounds...and you want clarity and you want perfection go with focal!!! they have a 3 piece set for up fron and sweet coxials for the rear......its what i have and by far the best sounding speakers out there
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
MrMeanor
Sep 28, 2019 04:37 PM
Dutch_tC
Sep 7, 2015 05:13 PM
carid
Aug 7, 2015 11:32 AM
surfcitylocal
Aug 4, 2015 06:52 PM
