WILL SOMEONE INVENT DETATCHABLE NEONS??!?!?!
Old Mar 21, 2007 | 04:32 AM
Marvelous1's Avatar
Marvelous Scions
Default WILL SOMEONE INVENT DETATCHABLE NEONS??!?!?!
will someone invent DETATCHABLE NEONS or LED KITS, SO THAT WE CAN TAKE EM OFF EASYER, LIKE UNPLUG THE WIRE FROM THE END OF THE TUBE AND GET OUR TICKETS SIGNED OFF THEM PLUG EM BACK ON?!??!!
k thanks i love you guys all week
take care
peace!!
Old Mar 21, 2007 | 05:35 AM
toyotaisme's Avatar
is it illegal to run neon inside the car? or did you get a ticket for the under glow?
Old Mar 21, 2007 | 06:14 AM
Marvelous1's Avatar
Marvelous Scions
i got ticket(S) for underglow!!
Old Mar 21, 2007 | 06:15 AM
Neothin's Avatar
what color were you rockin when you got the ticket?
Old Mar 21, 2007 | 06:30 AM
Marvelous1's Avatar
Marvelous Scions
green, blue, flashing blue green, then the next night rockin red and blue =0) then the night after that i got another ticket for just green =0)!!
Old Mar 21, 2007 | 06:31 AM
Neothin's Avatar
dont run red or blue lol
that's a duh move on your part, sorry :-/
Old Mar 21, 2007 | 01:26 PM
spECIal's Avatar
were u driving with them on???
cause it shouldnt be a ticket if u were parked
Old Mar 21, 2007 | 02:44 PM
toyotaisme's Avatar
are they just fixed up tickets or are they expensive?
Old Mar 21, 2007 | 03:52 PM
exmurderblah's Avatar
quit driving with them on david!
Old Mar 21, 2007 | 04:31 PM
Sid_xBicious's Avatar
david,
just cut the wires before the lights, then crimp a pair of this:
Old Mar 21, 2007 | 04:46 PM
he can't do that. he has the inferno kit. you can't cut and splice any o the wires. its like an ethernet cable type wire/phone line.
Old Mar 21, 2007 | 04:54 PM
Frosty355's Avatar
It is a good idea, however. I would like a quick disconnect so I could remove them in the winter. Mine took an ice chunk and cracked. who knows how long they will last before I have to buy a new set and re-run the whole thing.
How easy it would be just to replace the broken one if they could do that.
Old Mar 21, 2007 | 05:03 PM
Neothin's Avatar
you can buy replacement tubes frosty....
Old Mar 21, 2007 | 05:06 PM
well, my bad. I thought he meant the regular neon tubes, or single light tubes. anyways, depending on how many wires he has in one light tube, he can look into those wire connectors from radioshack and find a match. same principle, cut and attach a male/female connector.
Old Mar 21, 2007 | 05:13 PM
I read somewhere on here that if you cut the wires and re splice them you will have problems with the lights. they will flicker. go on and off like if there was a shortage
Old Mar 21, 2007 | 05:19 PM
kevinjr03's Avatar
You could probably use some DB-9 connectors from radio shack, and solder the wires in. As long as you put the wires in the right places you won't have a problem.
Old Mar 21, 2007 | 06:17 PM
emokid158's Avatar
use male/female rj45(ethernet) connectors or rj..11?(phone) connectors. only problem is that those connectors are a little bulky, so you might want to mount them under your car or put them inside the car. if you're worried about flicker, looks like you'll need to buy another set to test that theory.
Old Mar 21, 2007 | 08:21 PM
Frosty355's Avatar
Thanks, but I already knew that. What I am trying to avoid is rerunning the wire to the control unit. If it disconnected at the light tube it would make it easier.
Sorry I didn't make that clear the first time I posted in this thread.
Old Mar 21, 2007 | 08:34 PM
emokid158's Avatar
if the rj45(ethernet) connectors or the rj11(phone) connectors would work, you could just put the female end on the feed line from the hub and mount them in locations near the tubes, and then whenever you get new tubes just plug the male end into the female end that's already mounted on your car.
Old Mar 21, 2007 | 08:56 PM
DiStUrBeD_AzN's Avatar
Unique Scionikz
Wth, when did david jock my Oznium underglow!~
