What is up with the xB Power Antenna?
Old Mar 24, 2007 | 08:26 AM
SkeetermacXB40's Avatar
Default What is up with the xB Power Antenna?
I just put a HD tuner into my xB and the radio reception got a little better but still fuzzy...are there any Antenna upgrades out there?
Old Mar 24, 2007 | 09:19 AM
Tomas's Avatar
Admin Emeritus
Are you powering the built-in antenna amplifier with your head unit? If not, that may be your problem.
See: http://www.clubxb.com/forums/f23/45-radio-reception/
Old Mar 24, 2007 | 12:00 PM
J1slim's Avatar
thats what i forgot. i thought power antenna...um no... boy was i wrong..!!
Old Mar 24, 2007 | 12:56 PM
low_down_xb's Avatar
i tried all sorts of stuff to make the reception better but no luck so i just went with the sirius radio, much better in my opinion then normal radion, but thats just my 2 cents on that
Old Mar 24, 2007 | 03:24 PM
mom2boysdadsxb's Avatar
Because of the rear glass mounted antenna on the xB,it requires an antenna amplifier.The amplifier requires 12 volts when you turn on your tuner.Most tuners have a lead with the correct output.You just need to connect the amplifier lead from your new deck to the black with red wire, pin 8,connector A, and it will work perfectly.Good luck.
Old Mar 24, 2007 | 08:12 PM
raceronabudget's Avatar
ah this is what i must have forgotten. haha thought it was for a power antenna. d'oh
Old Sep 17, 2012 | 06:40 PM
scion50bx's Avatar
Default Antenna Booster Q
For 2005 xB, I just need to connect the black with red wire, pin 8, connector A to the power antenna wire on the new head for the antenna booster to work?
http://www.crutchfield.com/p_1207017...77#details-tab
Old Sep 17, 2012 | 09:10 PM
Tomas's Avatar
Admin Emeritus
Yes, that should do it.
Old Oct 26, 2014 | 10:02 PM
JACKNBX's Avatar
See: Radio Reception.. - Scion xB Forum
I put a JVC head unit in 2 years ago and thought to myself.....that figures the fm/am reception sucks, it was alright though, I used my iPhone and with bluetooth had everything I needed. So this week my daughter just turned 16 and she wants a better stereo than the factory am/fm cassette that is in her 2002 Forester, so I do some research to see what I need to do and it's like..... what power for the antenna....the thing is in the window, it don't go up and down. Well a little more research and I learn about the amplified antenna. Remembering that I left that wire unused in my Box(because my antenna don't go up and down..... haha), I pulled the unit out hooked up the wire and WOW, all kinds of reception. I guess I'm too old school....when I was young power antenna's where on high-end cars....not toasters!
wonderworm
Nov 19, 2023 01:44 AM
Inazuma
20
May 3, 2023 01:58 AM
missing_image
Feb 7, 2015 07:18 PM
sithscripter
Mar 31, 2004 04:02 AM
TJ
Nov 6, 2003 01:16 AM
