Getting Wires Inside The Car...
Old Mar 28, 2007 | 04:06 PM
ROBs-xB's Avatar
Default Getting Wires Inside The Car...
Ok peeps, I may end up buying some puddle lamps for my Box side
skirts, but I dont know how to get the wires from outside the car to
the inside, How do you do it?
Thanks
Old Mar 28, 2007 | 04:12 PM
Frosty355's Avatar
There are grommets in they engine bay and the floor. Just poke a small hole and run wires all day long.
The ones in the floor are easier but the engine bay is cleaner.
burstaneurysm's Avatar
There are rubber grommets under the car. Cut a small slice in one and pull the wiring through.
Old Mar 28, 2007 | 04:13 PM
Frosty355's Avatar
Oh ho! I beat you by a second.
Old Mar 28, 2007 | 04:16 PM
ROBs-xB's Avatar
ok cool, now where exactly in the floor are these grommets
Old Mar 28, 2007 | 04:17 PM
Frosty355's Avatar
You can find them by lifting up your carpet or looking under your car.
Old Mar 28, 2007 | 04:18 PM
ROBs-xB's Avatar
Alright, Thanks
Old Mar 28, 2007 | 04:20 PM
pooder's Avatar
After pulling wires thru the grommets, put a dab of silicone sealant on where they went thru; that will help ensure that water never does.
Old Mar 28, 2007 | 04:59 PM
Frosty355's Avatar
Good idea.
Old Mar 28, 2007 | 05:24 PM
Yea... damn.
Old Mar 28, 2007 | 07:02 PM
HeathenBrewing's Avatar
I didnt want to mess with lifting the carpet and such...seemed like a big hassle.
On the passenger side engine bay, there is a large bundle of wires going into the firewall through a large grommet. On both sides of the grommet are to long nipples. Cut the tip off and slide your wires right on through. A dab of silicone into the nipple insures a waterproof seal.
Old Mar 28, 2007 | 09:54 PM
TerribleTed's Avatar
You can easily slide even a 4guage wire thru the main wire bundle firewall grommet near the steering column. A small slice somewhat toward the center but not in the protruding part where the wires are will work and allow protection from shorting against the outside edge of the hole (access to this grommet is pretty good on both firewall and interior sides). The large rubber grommet toward the right side of the firewall has 2 nipples that can be opened for passing wires also, acces to grab them and pull them thru here is difficult from the inside tho.
Old Mar 28, 2007 | 09:58 PM
Frosty355's Avatar
You crazy. it's no big thing. no glue, tape or sticky stuff at all. come up easy. But, me personally, I would use the ones in the fire wall.
Old Mar 28, 2007 | 10:08 PM
cherryBox's Avatar
here's one way to do it, using a screwdriver that I ground the edges off of. I taped the wire to the blade and used the screwdriver to push thru the grommet.
you can see the grommet at the firewall, behind the strut tower
this is a view straight up from the clutch. you can see the red handle of the screwdriver.
nothing has moved in this pic, but i've put it here for reference. the wire is the same wire you see in the earlier pic.
the red tape at the end of the screwdriver is much easier to see than black. just undo the tape, and pull the wire up. don't forget to put the screwdriver away.
voila!
Old Mar 29, 2007 | 02:15 AM
OldYeller's Avatar
Nice pics CherryBox. Thats how I did my Randode engine lights per the directions.........
Old Mar 29, 2007 | 02:51 AM
swartzautoman's Avatar
a good langth of a metal hanger workes better then a screwdriver, easier to find and grab!
Old Mar 29, 2007 | 03:05 AM
raceronabudget's Avatar
thats what i've been using.
Old Mar 29, 2007 | 04:01 PM
Frosty355's Avatar
Great Pics! Thanks for taking them. Very helpful!
Old Mar 29, 2007 | 04:20 PM
chipzxb's Avatar
Nice job there Tony.. Good pics buddy.
Old Mar 29, 2007 | 06:52 PM
cherryBox's Avatar
agreed, and I use a hanger quite a bit. in this case, I felt that the screwdriver was more precise, and easier to control. it's a personal choice.
