Do I have to put stock injectors in if I have a stock ECU?
Old Mar 29, 2007 | 08:40 PM
dachmo's Avatar
Default Do I have to put stock injectors in if I have a stock ECU?
I have the TRD 44cc Injector on my car because I just took off the SC. Can I run the 440's with a stock ECU?
Old Mar 29, 2007 | 09:01 PM
Angry_Celi_Guy's Avatar
you will prolly throw a rich code, seeing that there is less air without the sc. im sure u CAN run them but your car prolly wont run as strong with an impropper air/fuel mix.
Old Mar 29, 2007 | 11:29 PM
RSracer's Avatar
No, your car will idle with a violent shake! Well at least it does with 550s. Trust me I know...
Old Mar 29, 2007 | 11:51 PM
bcnu_702's Avatar
I agree, it may not be as violent as the 550c's RSracer had due to the smaller size injectors, but it will have a violent and uneasy idle to say the least. Not a good idea to keep them on without the supercharger.
Old Mar 30, 2007 | 02:09 AM
ERIC-TC's Avatar
If you have a flashed ECU then yes you can run the 440cc injectors without the blower...but you have to keep the SC air-box that the MAF is mounted to.
If you replace the air-box to the stock model then you need to change out the ECU and change out the injectors as well.
There is a post from Garage witth info that will allow you to re-program an ECU off a doner vehicle. You need a new non-flashed ecu to go back to stock.
Old Jul 29, 2007 | 07:17 PM
jetlounge's Avatar
i thought the kit came with 400cc, not 440's...
JM Auto Racing
Dec 19, 2014 06:36 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
eric_m
79
Mar 17, 2013 12:21 AM
greenbox
19
Oct 22, 2003 12:29 AM
