Changing my spark plugs
Old Sep 1, 2004 | 02:31 PM
Money's Avatar
Default Changing my spark plugs
My question is can I use the echos spark plugs with no problem. Im trying to upgrade off the stock plugs. One of my main reasons is that I need a bit more spark to burn off the gas introduced to the engine do to upgrades.
Old Sep 1, 2004 | 11:23 PM
XBman's Avatar
I definatly do see why not. Bieng as that the echo and the XB share the exact same engine. Make sure you get the right plugs for your box. I recomend Bosh plugs my self.
Old Oct 11, 2004 | 03:02 AM
sonicimpulse's Avatar
OhioScions
I agree I would go with some Bosh Platinums. Plus they come preset for your car.
Old Oct 11, 2004 | 03:40 AM
chucksu's Avatar
I dont see why not. A question about the plug gap was asked ( https://www.scionlife.com/forums/vie...ight=echo+plug ) but seems the echo ones would work. Just dont waste the money on the real high priced ones ( https://www.scionlife.com/forums/vie...t=5257&start=0 ). Also some 1NZ-FE engine specs ( https://www.scionlife.com/forums/vie...ght=spark+plug )
Old Oct 11, 2004 | 05:39 PM
bondobob's Avatar
N.G.S.O.
NKG OR NIPPON DENSO get the heat range for your engine,never had problem with either.
Old Oct 11, 2004 | 05:47 PM
bondobob's Avatar
N.G.S.O.
bondo again
i forgot to tell you change your plugs with your engine cold, as with a hot engine you could pull some threads out of the head,very baddd! use a small amount of anti seize compound on your plug threads when you install.
Old Oct 11, 2004 | 11:03 PM
bB2NER's Avatar
Music City Scions
have had good luck with the bosch platinums
Old Oct 11, 2004 | 11:19 PM
PushyTop's Avatar
Default Spark Plugs...
I've had sucess with the NGK Iridium plugs (BKR5EIX).
kleecker
Jul 11, 2015 09:39 PM
daniinpitt
Apr 4, 2015 08:07 PM
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
jenkay
Dec 17, 2014 03:25 PM
