Changing my spark plugs
My question is can I use the echos spark plugs with no problem. Im trying to upgrade off the stock plugs. One of my main reasons is that I need a bit more spark to burn off the gas introduced to the engine do to upgrades.
I dont see why not. A question about the plug gap was asked ( https://www.scionlife.com/forums/vie...ight=echo+plug ) but seems the echo ones would work. Just dont waste the money on the real high priced ones ( https://www.scionlife.com/forums/vie...t=5257&start=0 ). Also some 1NZ-FE engine specs ( https://www.scionlife.com/forums/vie...ght=spark+plug )
bondo again
i forgot to tell you change your plugs with your engine cold, as with a hot engine you could pull some threads out of the head,very baddd! use a small amount of anti seize compound on your plug threads when you install.
daniinpitt
Apr 4, 2015 08:07 PM
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
