DO I HAVE TO REFLASH MY COMPUTER????
Old Apr 8, 2007 | 03:32 PM
retrojay2345's Avatar
Default DO I HAVE TO REFLASH MY COMPUTER????
Whats up, well i just installed a custom intake and for some reason my check engine light is on, do i need to reflash the computer or what? anyone have this problem?
Old Apr 8, 2007 | 03:34 PM
trialsindude's Avatar
Strictly Scionized
Door number 1 says, reset the ecu
Old Apr 8, 2007 | 04:12 PM
redwar1441's Avatar
custom? as in homemade? the air fuel ratio of the engine is determined by the exact size and shape of the mass airflow meters mounting location. This has to be exact. IF its not your fooling to ecm and the car will not run right. Go get the code read, it could be an overly rich/lean code, or you could have damaged the maf sensor. Or it could not be related. Either way it cannot be fixed without knwing what exactly caused it.
Old Apr 8, 2007 | 04:40 PM
CuRiOuSfIsH's Avatar
reflash and reset are 2 different things.
Even if you reset the ECU, it will just put up the same code after a few minutes of driving.
Old Apr 8, 2007 | 06:56 PM
Ty_Max's Avatar
Did you disconnect the negative when you where putting the exhaust on?
It says on most exhausts when putting them on to make sure you disconnect the negative for 10 seconds then putting it back on then starting the car to make sure the car doesn't sense something is wrong.
Old Apr 8, 2007 | 10:54 PM
redwar1441's Avatar
who said anything about an exhaust?
Old Apr 9, 2007 | 10:18 PM
DarthVadertC's Avatar
.... your
Old Apr 10, 2007 | 12:24 AM
Mid_Life_tC-risis's Avatar
Retrojay, if you haven't already, disconnect the battery's negative terminal, wait about 30 seconds, and re-connect. This will RESET the ECU - no need for a reflash - and allow it to begin adjusting to your intake's new (presumably) higher air flow when you start it back up. Your intake's instruction sheet should have mentioned this.
If you still get a CEL do what redwar said and have the fault code read. If you don't have access to an OBD-II code reader try Autozone or another auto parts store. Many will scan your codes for free.
By the way what brand of intake is this and are you sure it's compatible with your model year tC? (2007 has different MAF sensor than '05/'06.)
Old Apr 11, 2007 | 04:23 AM
soros151's Avatar
I actually think u should disconnect it for various minutes, just to be sure. That's why it's best to disconnect the battery while doing breathing mods. Also not to burn out a sensor. I say this because here in SL someone fried their sensor on the TB while changing to an Alphawerks.
Blunderbuss
Oct 8, 2015 04:56 PM
DryToast
Aug 4, 2015 02:59 PM
herbn44
Jul 24, 2015 02:26 PM
