HELP cant turn off electrical power
Old Apr 13, 2007 | 08:04 PM
miamiBASS's Avatar
Default HELP cant turn off electrical power
Just right now I got home.. took the key out of the ignition and radio stays on? I was like WTF?
I tried inserting and removing key several times and starting several times but doesnt help... I cant power off anything... I had to manually turn off the radio but my 12v powerjacks still have power.. and so does my amp.
Im assuming the problem might be in the ignition hole.. should i try to open it up? if so is there a DIY somewhere on this website..?
got to fix this asap
Old Apr 13, 2007 | 08:17 PM
Spect2K3's Avatar
Did you just install an audio system? If so, did you wire it correctly for power (to turn on off with the ignition - use of the ignition wire) or did you wire it directly to the battery. If you did it straight to the batt, that's your problem
Old Apr 13, 2007 | 08:21 PM
Zebman's Avatar
The 12v plugs would turn off regardless.
I honestly don't know what is wrong. I would try undoing the battery for 10+ minutes, then hook it up again, reset the windows, and see if the problem is still there.
Old Apr 13, 2007 | 08:28 PM
Spect2K3's Avatar
In reality, if your on the east (based on your name), the dealer is open for another 30 minutes....tell em its an emergency b/c your battery will drain. -----but only do this if you KNOW that it is NOT something you did to the car as they will charge you an arm and a leg. If not, it'll be covered under warranty if your under 3year/36000
Old Apr 13, 2007 | 08:30 PM
miamiBASS's Avatar
I installed my system over a year ago.. its connected properly. cant be it.
Im going to try unplugging battery for ten minutes.. lets see what that does
My 12v plugs always turned off if i remember correctly.. i remember my cell or ipod wouldnt charge with key out of ignition
Old Apr 13, 2007 | 08:35 PM
Spect2K3's Avatar
Yes, the 12V should definitely turn off in the tC
Old Apr 13, 2007 | 10:10 PM
miamiBASS's Avatar
I touched the cigarette lighter and it suddenly turned off... everything is ok now.. gonna keep the cigg lighter disconnected.
weird.. hope it doesnt come back
Old Apr 14, 2007 | 02:36 AM
Spect2K3's Avatar
Glad to hear everything is okay. Hope that doesn't happen again, but at least you know how to temporarily fix it
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
GoodVibes
Mar 10, 2015 04:29 AM
setpol
Feb 17, 2015 11:33 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
ScionRo
Jan 2, 2015 07:54 PM
