GreenLantern
04-18-2007, 09:46 PM
like the title was wanting to see where peeps put there edfc head unit so I can get an idea where I want to install/put mine
thanks!
thanks!
View Full Version : post pics of your edfc controller!! GreenLantern 04-18-2007, 09:46 PM like the title was wanting to see where peeps put there edfc head unit so I can get an idea where I want to install/put mine thanks! Ekolu2004 04-19-2007, 08:57 AM how's it! I did mine almost two years ago and at the time we had to just rush it cause one of our biggest car shows was coming up so here it is. http://i169.photobucket.com/albums/u214/frickinflip/IMAGE_111.jpg i'll post one more picture. http://i169.photobucket.com/albums/u214/frickinflip/IMAGE_109.jpg EZ-BAKED 04-19-2007, 01:18 PM I still need to install myn was thinking the same spot. but rethinking it now that i see it. that kinda kills alot of free space. Ekolu2004 04-19-2007, 05:24 PM I know it kills the extra space in the oven. I wanted to install mine in that little space right under the mirror switch but the fush box was in the way, another spot would be right by the e-brake but I still don't think would hav enough space. the EDFC controler is kinda big but I think if you have a single din deck then it would fit perfectly in that little extra space. EZ-BAKED 04-19-2007, 06:07 PM maby fab up somthing and remove the ashtry. GreenLantern 04-19-2007, 08:50 PM I'd like it set in on the left side where I put my sunglasses (under the miror controls) but would want it flush against the back wall..so as to not really be seen ....will have to think about it it's not that big...could put it down by the E brake maybe? facing up...just depends on how well it will look BoiseAuctioneer 04-20-2007, 12:22 AM How do you like the EDFC? Does it adjust your height in the slightest bit? How is the ride? Do you continually use it or is it something you used at first and then stopped? Thanks Ekolu2004 04-20-2007, 01:35 AM How do you like the EDFC? Does it adjust your height in the slightest bit? How is the ride? Do you continually use it or is it something you used at first and then stopped? Thanks I wish the EDFC would control the height. it's an electronic dampening force controler, so it just adjust the dampers for the front and back. I use mine almost everyday depends where I drive and how the road condition is. when i'm on a mountain road i'll set it to 2 in the front and 0 in the back so it handles the turns, when i'm in town i'll leave it to a softer setting like 13 in the front and 10 in the back. so the higher you go in numbers the softer the ride is. |
