Squeak/Squeal from engine (louder with A/C on) Advice!
Old Apr 28, 2007 | 01:52 PM
AKgoalie7's Avatar
Default Squeak/Squeal from engine (louder with A/C on) Advice!
Alright, here's the deal. It's pretty much been doing this for the life of the car (46k miles) and it's now getting worse. I just shrugged it off before as just some engine noise.
When i throttle and start to take off, there's like a stream of continuous squeaking/squealing noise coming from the engine. It's much louder and noticeable when the A/C is running.
i know what a slipping belt sounds like and it doesn't sound like that at all. It has more of a "rattle" sound to it. It only happens while driving, not parked or neutral. It's faint without the A/C, louder with.
To me it sounds like a squeaky wheel or something going around and around, with a slight "tink tink tink tink tink" to it. Maybe a squeaky/warped pulley?
I'm not sure. That's why I need your help, or if anyone has heard of this before. I searched around and saw squeak with throttle cables but I dont think this is it.
If i have to, i'll drive around the neighborhood and try to "record" the sound.
My only engine "modifications" are a injen short ram CAI and ground wire kit.
Old Apr 28, 2007 | 03:22 PM
stew32's Avatar
Sounds like you are on the right track with the belts/pulleys. Does the xB have an idle pulley? Could be bearing in it gone bad. If it doesn't, could be a bearing in the alternator, a/c, etc.
If you haven't replaced the belts, now would be a good time. If you have, maybe there was too much tension and caused a failure.
06ScionTc5sp1
9
Oct 16, 2020 01:18 AM
hydrogen
Jul 14, 2020 09:41 PM
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
StatuSCheckA
Scion tC 2G ICE & Interior
Dec 4, 2014 03:15 PM
