CHEAP DOOR SPEAKER SPACERS
Ok so I installed my new 6.5" door speakers this weekend and I ran into a big problem. None of my local shops had the spacers I needed. I really did not wont to wait to order them in, afterall the sun was out and wonted to go cruising. So after closer inspection of the factory units I realized that they would work fine as spacers.
It was pretty simple to do so here go's.
After you remove the speaker from the door cut the rubber that connects the speaker to the plastic case. Next break off all the tabs that connect the speaker to the case with some pliers. At this point the speaker should fall out of the case, cut the 2 wires and presto you have a spacer. Clean it up with some sand paper and mount your new speaker in the old case. And yes there are spots on the old case to screw in the new speaker. (You will have to look and see where). If u wont to u can wire up the speaker with the wire harness and no wire splicing will be need.
I know the new spacers really are not that expensive but hey u can't beat some thing that is free, and now u have a couple of bucks to spend on something else for your scion.
L8ter all.
L8ter all.
DaBlackBox
134
Apr 10, 2022 02:04 PM
MyNameIsMud
Scion FR-S ICE & Interior
Mar 4, 2015 05:27 PM
IWontBeIgnored
Dec 4, 2003 04:46 PM
