where did you mount your XM/Sirus/GPS antenna?
Old May 1, 2007 | 07:33 PM
blazeplacid's Avatar
Default where did you mount your XM/Sirus/GPS antenna?
i have Xm right ,the antenna is on the inside (looks ok where its at,tucked very far in the passenger dash) the recption is good but not great,it cuts out alot. I tried it behind the Pillars but it was worse. How does GPS work when mounted thier?
any help??
Old May 1, 2007 | 07:50 PM
O5_TRD_tC's Avatar
gps works fine being the pillar for me
Old May 1, 2007 | 07:54 PM
equinox2355's Avatar
My GPS is mounted under the dash in the air vent for the top air (the vent right above the HU once you take the "cover" off ( I get 4 out of 5 or 5 out of 5 for GPS signal )
Old May 1, 2007 | 08:21 PM
Spect2K3's Avatar
My GPS is mounted there along with my satellite radio. The gps works perfectly.
Old May 2, 2007 | 12:58 AM
ScionSteve66's Avatar
I have an after market XM tuner with one of those magnetic antenna things. I ran the wire out through the back seat and stuck the antenna to the hatch. It's under my pedestal spoiler and I never lose signal. If it works there, I'd imagine it'd work anywhere.
Old May 2, 2007 | 03:00 AM
nd4spd_4_a_tc's Avatar
R/S of the dash 2" from pillar. Stock xm was in the middle of the dash. Removed that since XM sucks *****.
Old May 2, 2007 | 03:24 AM
Neothin's Avatar
my AVIC-D2 gps antenna is under the dash on the passenger side
Old May 2, 2007 | 03:30 AM
ricexizxgood's Avatar
Bottom right corner of the windshield. I was at first worried about exposing too much sunlight to it but its been there for almost 2 years and its still fine.
Old May 2, 2007 | 03:41 AM
Shadows_Fall_xX's Avatar
mine comes out of a slot near my rear view barely noticeable!
Old May 3, 2007 | 01:19 AM
tjbartjr's Avatar
On near edge of the hood, centered between the two washer nozzles. Excellent reception.
Old May 3, 2007 | 02:15 AM
superiorauto's Avatar
GPS and SAT
Old May 3, 2007 | 02:24 AM
SquallLHeart's Avatar
my gps
now you see it..
now you don't..
Old May 3, 2007 | 03:12 AM
I like the sunroof idea. Do you think it would work for XM?
Old May 3, 2007 | 03:28 AM
you would have to test fit to see if it will... most xm antennas i've seen might be a little too big.
Old May 3, 2007 | 12:41 PM
Well I have mini XM antenna,so the sunroof thing might work
Old May 3, 2007 | 01:28 PM
I meant in terms or reception, not fit. Heck I hadn't even thought about that!
Gonna go check right now...
Old May 4, 2007 | 12:31 AM
It works! Now I just gotta find a decent place to mount the tuner.
Old May 4, 2007 | 02:01 AM
mine will be installed into my stock radio and all i have to do is click the SAT button and ill be good
Old May 4, 2007 | 02:10 AM
You mounted the antenna before you hooked up the tuner?
Old May 4, 2007 | 02:12 AM
nebster's Avatar
you see them?
