Descendant Turbo Install Wastegate to Atmosphere?
Old 05-10-2015, 08:05 AM
skruff's Avatar
Default Descendant Turbo Install Wastegate to Atmosphere?
I'm installing a descendant turbo on my 06 and can not for the life of me figure out where the wastegate dumps to. Is anyone familiar with this kit? Do I really just let the wastegate dump to atmosphere down next to the start of the s pipe?
skruff is offline
Old 05-14-2015, 01:00 AM
ScionCREW's Avatar
Yes that how it was made.
ScionCREW is offline
Old 05-14-2015, 02:32 PM
Scionetics
KAD
paul_dezod's Avatar
Art! Whoa. How the hell are ya?
paul_dezod is offline
Old 05-15-2015, 01:46 PM
skruff's Avatar
Very strange IMO. I am having trouble with the turbo since I got it back from the tuner. Everything was fine and dandy for a day. Now the engine bogs down as soon as the turbo spools up and vac turns to boost.
It happens in all gears, and only if I am accelerating semi hard or going up a steep hill. I ran the car on idle and sprayed all my vac lines and intercooler couplings with choke cleaner and couldn't find a leak. What would be the next step?
The tuner was supposed to call me back yesterday but still hasn't.
skruff is offline
Old 05-15-2015, 08:56 PM
bbsciontc's Avatar
Sounds like a boost leak. Pressurize the system with the car off using shop air set to a low pressure on the regulator (10 psi max). Let me see if I can find a similar post I made for someone else.
bbsciontc is offline
Old 05-15-2015, 08:59 PM
bbsciontc's Avatar
Here it is:
I used a pvc end cap the same size as my charge piping and threaded and sealed an air hose fitting into the flat end. I then attached it to a coupler from my intake piping and gave it about 8-10 pounds of pressure from my air compressor while the engine was off. This way, it is silent (after your compressor is off obviously) and you can listen all around the engine bay to try and locate a leak.
Old 05-15-2015, 10:36 PM
ScionCREW's Avatar
Whats up. Paul how business going?
Old 05-15-2015, 10:51 PM
ScionCREW's Avatar
Take it back to your tuner and let him drive it so he can diagnose the problem.
Old 05-18-2015, 01:43 PM
Scionetics
KAD
paul_dezod's Avatar
Good Art. Very good start to 2015. Zero complaints.
What are you doing now-a-days?
Old 05-18-2015, 08:22 PM
ScionCREW's Avatar
Just trying to stay alive. I'm Back working at World Motorsports
Old 05-19-2015, 01:21 PM
Scionetics
KAD
paul_dezod's Avatar
Tiz the way of the world Art. I hear you loud and clear.
How are things at World? Tell Chris I said hi.
Old 05-20-2015, 12:31 PM
skruff's Avatar
Originally Posted by bbsciontc
Here it is:
I'll try this today. Thanks so much.
If I still can't locate a leak I'll get in contact with the tuner. I'm just hesitant about that because it's an hour away and they aren't open past 5.
skruff is offline
Old 05-28-2015, 03:00 AM
skruff's Avatar
Ended up being either a loose clamp around the bov or a leak between the headers and turbo manifold (or both). Resituated the turbo and then rebolted the v band clamp and that leak was gone. I also ended up ordering a new hose and clamp for the bov which fixed that issue at the same time.
skruff is offline
Brammi
11-13-2016 03:46 AM
my06tc
06-25-2015 12:18 AM
Frustratez
02-26-2015 04:03 PM
bushdog
02-22-2015 03:04 AM
TheRedBox
31
12-02-2003 04:53 PM
Quick Reply: Descendant Turbo Install Wastegate to Atmosphere?
