Larger throttle body?
Old 02-18-2015, 01:01 AM
Greg S's Avatar
Default Larger throttle body?
Question, has anyone who is boosted swapped to a larger throttle body?
If so what sort of gains did you get from it, dynode or seat-of-the-pants?
I've been looking at the Toyota V8 throttle bodies as a possible PnP swap since they come in 65, 70, & 75mm diameters. A big increase over the stock 55mm one.
Greg S is offline
Old 02-25-2015, 09:40 PM
TBurleson's Avatar
i was just reading about this alot of people are saying an rx-8 throttle body works but im looking up more details
TBurleson is offline
Old 02-26-2015, 08:24 PM
Greg S's Avatar
I looked through that and while it does work you have to swap the TPS sensor wires, I think the Toyota ones will just plug right in. Also discovered that for my use the 65mm is the largest I can go, so the RX-8 70mm would be a waste of money. The intake port on my supercharger is about 62mm and can't really be opened past 65mm without compromising the outer structure of the housing. Picked up a throttle body this week and it looks like I'll have to tap the fuel vapor line into the pipe going between the throttle body to the supercharger since the fitting isn't on the larger TB.
Greg S is offline
Old 03-05-2015, 02:35 AM
Flyfishfreak's Avatar
Does swapping to the Rx-8 help with the tune? I cant find it but i recall reading where someone said going to the larger RX-8 TB helped with some stalling around 2800-3200 RPM's? I know my tuner had some issues with my AEM FIC in that range but i could never find the info :/
Flyfishfreak is offline
Old 03-05-2015, 07:29 PM
Greg S's Avatar
Honestly I don't know. If it was stalling due to not enough air flowing into the intake manifold then yes it probably would help. I think it would only happen if the infectors were quite a bit oversized and weren't able to have the pulse cycle shortened enough to stop an over rich situation.
The problem I'm running in to is that most, if not all, of the cars that have done a larger TB are turboed and doing a blow through set-up which doesn't have as much of an issue with undersized TBs as what I'm doing with a draw through supercharged system. Draw through set-ups are much more sensitive to TB size as it can be a major restriction in getting air into the engine.
You can always try one and see. It's no more than $100 for a used TB off one of the larger Toyota engines, more if it's off the 5.7 V8, or the RX-8.
Greg S is offline
Old 03-05-2015, 10:39 PM
Yeah not sure why i have not just bought one. Im going to try and dig up the thread again as well.
Old 03-06-2015, 05:39 AM
dc5chris209's Avatar
I read a thread earlier that said a 1zz throttle body bolts to the XB. I was thinking of doing this on mine.
Pretty sure it's a 60mm opening.
dc5chris209 is offline
Old 03-06-2015, 04:16 PM
k1114's Avatar
I'm not sure sure about the mounting; many of the 1ZZ TBs I've seen use a 3 bolt mount and cable drive.
k1114 is offline
Old 03-06-2015, 04:57 PM
The TC is drive-by-wire, correct?
I was able to find a few 1zz variants the 98 -02 corolla and newer Camry seems to have a similar TB.
I'm curious to pull the engine drawing up to compare the bolt patterns.
Old 03-07-2015, 04:48 PM
tom0613's Avatar
Do not waste your money on it.
tom0613 is offline
Old 03-07-2015, 05:30 PM
Did you give this mod a try? I'd assume it wouldn't run right without some sort of tuning.
Old 03-09-2015, 05:30 AM
lol, so many "hell no," and "don't bother" type responses on this forum lately. What happened to actually contributing to the discussion? Maybe even volunteer some information or personal experiences?
Old 05-26-2015, 11:28 PM
Music City Scions
BlackKnight's Avatar
What size IC pipe are you running? If you are not running bigger than 2.5" its pointless to go bigger than 55mm.
BlackKnight is offline
Old 05-27-2015, 12:14 AM
Greg S's Avatar
I'm not running and air-to-air intercooler, I'll be using an air-to-water setup due to space constraints. I'm going to give the 65mm a run once I have everything set up since that will keep a consistent 2.5" diameter from the intake into the inlet of the S/C body.
Greg S is offline
Old 05-27-2015, 01:18 AM
Music City Scions
Doesn't matter which type of IC both still have pipes ones just way shorter.
Old 05-27-2015, 07:59 PM
Greg S's Avatar
No, mine is actually going to be built into the intake manifold. No piping at all, the output of the S/C blows directly through the heat exchanger into the intake plenum chamber and straight into the head. Similar to the stock Cobalt setup like this one, Cobalt SS Supercharged LSJ supercharger Kit Intake Manifold Injectors Brackets | eBay
Greg S is offline
Old 05-27-2015, 08:24 PM
Music City Scions
I understand exactly what you are saying but there will still be minimal piping and the water to air has inlet and outlet size.
Old 05-28-2015, 12:46 AM
Greg S's Avatar
In a normal set up where you buy a built intercooler yes you would. I'm not doing that.
Here this might make it a little easier to see what I'm doing.
This is my supercharger which will be mounted on the backside of the motor close to how it is pictured.
I will be making an intake manifold between the supercharger and the head. The upper half will be the plenum chamber with runners going to the head. The lower half will have the one of the heat exchangers for the air-to-water intercooler setup built into it directly in front of the output of the supercharger's rotors.
This is the core that I'm using.
It will sit across the whole opening of the S/C output. Once the air goes through the core it is in the intake manifold plenum chamber.
I guess you could consider the small space between the output of the S/C and the intake plenum as the piping but it will have a much larger cross sectional area than normal piping. If we think of it that way then yes the 'piping' of the intercooler is larger than 2.5".
Greg S is offline
Blunderbuss
10-08-2015 04:56 PM
MeDizzy
10-08-2015 03:31 PM
prescottn
09-13-2015 09:04 PM
Subaru86
Scion FR-S ICE & Interior
09-10-2015 08:11 AM
umnitza
09-01-2015 08:06 PM
Quick Reply: Larger throttle body?
