Turbo kit; don't want to tap into the pan
Old 08-29-2014, 09:45 PM
willyt's Avatar
Default Turbo kit; don't want to tap into the pan
I'm building a 2AZ for a guy who picked up a Turbonetics kit for his '05 tC. He sent the installation instructions so we would know how to tap the pan.
First off, I can't believe that Turbonetics actually tells you to punch into the pan and tap the sheet metal while it's still attached to the motor. That just blows my mind. Whatever.
What I'd prefer to do is tap into the aluminum upper pan, rather than the stamped steel part. The aluminum is nice and thick, and will hold whatever fitting we end up using MUCH more securely. Should also keep the return outlet above the oil line in the pan. This is easy to do, since right now, the upper pan is not installed yet.
That being said, we don't have the car. So, has anyone done this? Where would it be safe to drill and tap where the return line won't get in the way of anything else?
Thanks!
willyt is offline
Old 08-29-2014, 11:25 PM
tcer904's Avatar
i didn't know there was an aluminum upper pan...hmm
tcer904 is offline
Old 08-29-2014, 11:40 PM
That_Kid_Ju's Avatar
I think that's what covers the balance shafts and other stuff (not 100% sure). I don't think anyone has done that, but you shouldn't worry about tapping the lower oil pan. Most (if not all) of us F/I guys have the lower pan tapped with no problem. You should remove it from the motor first, then mark out where the fitting goes, then punch through and drill out the holes. You can either tap the pan or weld a bung onto it. Another alternative is Dezod's Insta-tap fitting (no tapping necessary). Just fit it into the drilled holes, use the provided self tapping screws and add a little bit of JB Weld to make sure it's nicely sealed and won't go anywhere. I've had mine that way for 3 years now and not a single issue with it (other than the screws protruding too much and scraping up the AN fitting, but you can just chop off the excess length once it's in and secured).
That_Kid_Ju is offline
Old 08-31-2014, 04:49 PM
willyt's Avatar
That'll be easy, as neither the upper pan* or lower pan is installed yet. The balance shafts have been completely eliminated, too. Manley rods, Wiseco pistons, etc, etc.
A quick search on here shows pretty good results with drilling into the oil pan, but it still worries me. I'm going to have to think about this a bit.
*Toyota calls it the "STIFFENING CRANKCASE ASSEMBLY". I'm used to the 2J's, which have an aluminum upper and stamped steel lower oil pan.
willyt is offline
Old 08-31-2014, 10:42 PM
o TaGGeD o's Avatar
Personally ive tapped a tc2 pan on the bottom and it worked out great for my build! But for the tc1 you can always use a sandwich adapter plate.
o TaGGeD o is offline
Old 09-02-2014, 06:23 PM
Scionetics
KAD
paul_dezod's Avatar
It's an easy process. Just tap the pan
paul_dezod is offline
Old 09-02-2014, 06:59 PM
willyt's Avatar
I realize it's an easy process. I just don't like where it's placed, I'd like to see it higher up, away from the ground. And not in stamped steel.
willyt is offline
Old 09-03-2014, 08:20 PM
willyt's Avatar
Did this instead. 1" hex 6061, tapped for 3/8" NPT. It'll be welded in place. Will update when done
Attached Thumbnails Turbo kit; don't want to tap into the pan-dscn5209.jpg   Turbo kit; don't want to tap into the pan-dscn5208.jpg
willyt is offline
Old 09-04-2014, 01:03 PM
criminaltc's Avatar
That is a perfectly fine spot.
criminaltc is offline
Old 09-05-2014, 03:46 AM
Just make sure the return hose length is adjusted and routed so that it's not rubbing on anything or hanging too loose. Most kits have the line cut to length assuming it's going to the oil pan. You have the fitting much higher.
Old 09-05-2014, 02:46 PM
burgandybomber's Avatar
That's a little over engineered but hey, it'll work. Plus it's different which gives you cool points Kind of funny he is built out on a Tnetics kit, assuming it's the stock kit.
burgandybomber is offline
Old 09-25-2014, 11:15 PM
willyt's Avatar
No idea, he apparently bought a used kit. Hope it's in good shape.
willyt is offline
ILikeTurtles
Scion tC 2G Forced Induction
03-06-2022 02:24 AM
Brammi
11-13-2016 03:46 AM
cessblood
09-15-2015 06:50 AM
my06tc
06-25-2015 12:18 AM
drobins27
10
02-02-2015 02:10 PM
Quick Reply: Turbo kit; don't want to tap into the pan
