2006 tC Radio not working
Old 10-30-2014, 07:28 PM
Terrybeirne's Avatar
Default 2006 tC Radio not working
So I initially had a battery that needed to be replaced. I took it to the auto store and the guy there accidentally grabbed a reverse terminal battery which resulted in him crossing terminals when he changed it. My car wouldn't start at all after that due to a blown alternator fuse. I replaced that, but my stereo still isn't working. Everything else works fine but the stereo won't even turn on. I checked the fuses for the radio under the steering wheel and they look fine, does anyone know what could be the issue?
Terrybeirne is offline
Old 11-01-2014, 12:28 AM
62Fender's Avatar
I think I have a radio diagram on PDF. Let me know if you'd like me to e-mail it to you.
62Fender is offline
Old 11-24-2014, 05:56 PM
TJenner2's Avatar
Is it a stock radio, or something else. If it is something else, there is most likely an inline fuse tapped into the +12v battery wire going to the radio. These fuses are usually around 10 amps or less and can pop quite easily from something like that.
TJenner2 is offline
Old 01-24-2015, 11:35 PM
hbtl300's Avatar
Check the rad no.1 fuse in the engine bay next to the battery. 20amp fuse.
hbtl300 is offline
Old 02-17-2015, 06:05 AM
airdoza's Avatar
Default radio dead
I have a similar problem. But I was switching amps and accidentally touched the remote wire from the amp to the power wire and my radio blew. I checked the fuse in the engine compartment that shows on the diagram in the owners manual and it is fine. It is a 20. Is there another one I need to find?
airdoza is offline
clickclickw00t
02-18-2015 08:57 PM
Beesh
01-09-2015 06:30 PM
Kiwibox
12-15-2014 09:46 PM
MaxPower
10-22-2003 09:22 PM
Quick Reply: 2006 tC Radio not working
