convenience light question
Old 09-25-2016, 10:02 PM
firepac493's Avatar
Default convenience light question
just purchased a 2006 TC for my daughter. Car is in excellent shape and everything works well. I do have one issue that I can't seem to figure out. The dome light does not come on when the keyless unlock in activated. Not sure if this feature in included in this model? also the dome light is intermittent when the drivers door is opened. i have removed the switch cleaned it and it checks out good with the meter.any help or clarification would be appreciated.
firepac493 is offline
Old 09-29-2016, 03:38 PM
jkois's Avatar
sounds like maybe the previous owner installed an after market alarm and may have messed with the "supervisory circuit". That is the one that turns on the dome after unlocking, and the light brightens up gradually. After getting in and closing the door, it should then gradually dim to off after several seconds.
If there was an alarm system installed, that may also explain the intermittent light with the door open. Maybe a loose wire somewhere. I used to have all the wiring diagrams, but not sure where they are now. If I find them I will send you the appropriate ones.
Good luck.
jkois is offline
Old 09-29-2016, 04:03 PM
jkois's Avatar
Well, what do you know, here it is. Enjoy.
Edit - This is the 2005 manual.
File Type: pdf
jkois is offline
Old 09-29-2016, 04:43 PM
jkois's Avatar
If anyone is interested, here is the 2007 model year wiring manual. I believe this is the last one for the 1st GEN tC.
Enjoy
File Type: pdf
jkois is offline
Old 10-03-2016, 06:22 AM
firepac493's Avatar
Default RE
Thank you for the info and the diagram. The alarm is a factory unit i believe. I know that when its activated the horn goes off. I think that its some kind of interior light control module. when I get time i will look at the diagram and try to trouble shoot.
eujin
02-23-2016 01:18 AM
mxwes
08-30-2015 09:11 PM
domincnTC
08-04-2015 01:47 PM
Prolific998
Scion tC 1G ICE & Interior
07-13-2015 01:41 AM
neless
06-01-2015 12:43 AM
Quick Reply: convenience light question
