Start up Problem
Old 10-31-2014, 06:34 AM
Mike4G93's Avatar
Default Start up Problem
I got a scion tc 2006 manual transmision and im having
this issue, sometimes y takes long to start up(Like 3 or 4 sec) and others start normaly, What can be?
Mike4G93 is offline
Old 11-02-2014, 12:24 PM
TTCCC's Avatar
You gave us way too much information. Give us a while to comprehend it all.
TTCCC is offline
Old 11-02-2014, 01:46 PM
Mike4G93's Avatar
okay np
Mike4G93 is offline
Old 11-04-2014, 05:14 AM
Mike4G93's Avatar
i was thinking could it be fuel pump problem or something? it got 44K miles and the engine had power idk what get into it xd maybe some relay problem? btw it make like some relay noise wend i feel it's taking longer to start the engine. I stop the inicion and you hear like some relay noise then i give it another try and start normally
Mike4G93 is offline
Old 11-04-2014, 08:39 PM
stayintrucha's Avatar
Check your battery if the weather is cold would lag to turn on
stayintrucha is offline
Old 11-04-2014, 10:03 PM
Mike4G93's Avatar
im from puerto rico it's a tropical weather most time hot and the battery is new it had 2 week of use
Mike4G93 is offline
Old 11-04-2014, 10:10 PM
Try cleaning your throttle body. Did this start to happen when you changed the battery? Does it only do it when cold? Does the battery have enough cold cranking amps to start up the car? A lower amp would still start the car but it would take longer.
Old 11-05-2014, 12:35 AM
Mike4G93's Avatar
no, the problem persists before and after i changed the battery. I gonna check cleaning the throttle body
Mike4G93 is offline
Old 11-05-2014, 01:11 AM
Try that and check your cables and terminals
Old 11-05-2014, 04:25 AM
62Fender's Avatar
Might you have another transponder key on your keyring interfering with the Scion transponder ECU?
62Fender is offline
Old 11-06-2014, 02:27 AM
Mike4G93's Avatar
the alarm dosnt work so it removed also the key control pad
Mike4G93 is offline
Old 11-06-2014, 06:09 AM
62Fender's Avatar
Not all diagnostic codes illuminate the check engine light. If you have access to a meter, you could see if something's throwing a code.
62Fender is offline
Sooby
Scion tC 1G Wheel & Tire
11
04-08-2020 11:51 PM
Jordly221
02-13-2019 05:29 PM
cid_mcdp
01-05-2015 02:45 PM
fluxingnation
12-26-2014 04:28 PM
BV19869
12-11-2014 06:05 PM
Quick Reply: Start up Problem
