Dangerous Suspension Problem. Please Help!!!
Old 03-19-2015, 06:30 PM
CapnChunk's Avatar
Default Dangerous Suspension Problem. Please Help!!!
Hey guys, this is my first post. i just bought my tC a couple weeks ago and did not notice this problem during the test drive. on the way home there were a few sweeping turns on the interstate. i was taking a right turn while accelerating, and all of the sudden the car jerks even more to the right. it didnt jerk the steering wheel at all, it stayed in the same spot as i was holding it. The car just turned sharper. ive noticed that this only happens while i am accelerating and only on right turns above about 35mph.
also, the guy i bought it from lowered the suspension i think about 1"-1.5" on lowering springs.
i jacked it up yesterday to see if there were any bent suspension components but everything looked fine. help would be greatly appreciated. thanks in advance!!!
CapnChunk is offline
Old 03-20-2015, 11:43 AM
ropes's Avatar
Put it back on the jack stands and check the ball joints.....Lower and the tie rods. Upper is attached to the strut, so check the bolts there.
If you're unsure what to look for, most shops will so a suspension & brake check for free or at least cheap.
ropes is offline
Old 04-07-2015, 09:05 PM
sciontc_mich's Avatar
I agree a reputable shop would help you out. Sounds like the bushings are giving way and the suspension is shifting. Also should go under there and check to see if everything is torqued/tightened (nuts/bolts).. I have a sticky here somewhere that explains the tightening of the chassis nuts/bolts that needs to be done periodically..
sciontc_mich is offline
Old 04-13-2015, 04:06 PM
mc1114's Avatar
My TC did not like being lowered. Last year I installed lowering springs, and it caused a noticeable axle vibration under load. Went back to stock height, and problem went away
mc1114 is offline
SloTC1
08-16-2018 02:45 PM
sciontc008
Scion tC 1G Aero & Exterior
01-20-2016 05:10 PM
prescottn
09-22-2015 01:30 PM
Subaru86
09-14-2015 12:51 PM
prescottn
09-13-2015 09:04 PM
Quick Reply: Dangerous Suspension Problem. Please Help!!!
