Installing longer studs on the rear - instructions?
Old 08-02-2011, 05:32 PM
Cabana's Avatar
Default Installing longer studs on the rear - instructions?
I have 8mm spacers on my rears and bought 50mm wheel studs to put on so I have more threads to grab. I found instructions for the front, but I'm sure the rear are more complicated. Anyone know of a post with instructions?
Front: https://www.scionlife.com/forums/scion-xa-xb-1st-gen-wheel-tire-1608/diy-installing-longer-wheel-studs-9900/
Cabana is offline
Old 08-02-2011, 06:38 PM
criminaltc's Avatar
come on dude... you do it the exact same way. There is no major difference from the front to the rear that you would need to know. Take off the caliper, then the rotor, then pound out old studs, then slide in the new studs, tighten studs up without rotor on til its flush, then put the brakes together and tighten the lugs up on the studs with the wheels on to 100lbs, no more than 100 otherwise you'll stretch the studs and you'll be screwed. Bam, theres your intructions.
criminaltc is offline
Old 08-02-2011, 06:39 PM
Cabana's Avatar
How come everything I read involves removing the hubs?
Cabana is offline
Old 08-02-2011, 06:42 PM
Cabana's Avatar
ah nevermind, I found something helpful on a different site
http://clubsciontc.com/forums/diy-in...acement-38816/
Cabana is offline
Old 08-14-2011, 10:04 PM
StreetSweeper's Avatar
i had to remove my hubs on my spacer install
StreetSweeper is offline
Old 08-15-2011, 02:35 PM
HKSpeed's Avatar
I was able to install my 5mm longer studs without having to remove the rear hubs. there was enough room between the hub and e-brake assembly to slide in the bolts. I gently tapped out the studs using a sledgehammer.
HKSpeed is offline
bbsciontc
Scion tC 1G Wheel & Tire
08-19-2019 01:46 AM
BManAmericae
01-18-2015 12:17 PM
cid_mcdp
01-05-2015 02:45 PM
TheRedBox
02-03-2005 02:00 PM
TheRedBox
31
12-02-2003 04:53 PM
Quick Reply: Installing longer studs on the rear - instructions?
