PT546-00140 installation on '11 tC
Hey everyone,
I'm currently trying to install the HU PT546-00140 on my 2011 tC.
I got all the adapters needed for the switch from the stock basic model I had (cant remember the Pt number).
I do not have the Bespoke Premium audio.
After plugging in all the cables, the radio turns on fine everything works except i get no sound of out it.
Do I need a new amp or something else i might be missing
Any help is greatly appreciated
Thanks in advance!
______
Thanks in advance!
______
I replaced my Pioneer HU with another aftermarket Pioneer HU. You may want to make sure you have the amp turn on wire properly wired up. Its been sometime since I did my install, but I believe it was a blue wire. If I'm no mistaken, it should be wired to an accessory power source so it would on when the key was turned to the ACC or ON positions. Also make sure all the connections are secure. The best method is solder and heat shrink.
PT546-00140 install in 2010 xB
Hey everyone,
im currently trying to install the HU pt 546 00140 on my 2011 tc.
i got all the adapters needed for the switch from the stock basic model i had(cant remember the pt number). I do not have the Bespoke Premium audio.
Do i need a new amp or something else i might be missing
any help is greatly appreciated
Thanks in advance!
Thanks in advance!
I have searched several scion club sites... haven't had any replies to posts. I've seen others post about this issue but haven't seen any answers... but a lot of guys have this deck installed in their xB... ANY HELP???
I recently installed the exact head unit as the OP and ran into the same issue with no sound. For reference, my car is a 2011 Canadian model tC. My issue was resolved with the installation of the antenna harness (part #: PT546-00120-AD). When I initially installed the unit I only plugged in the 28 pin harness (part #: PT546-00120-CH) which produced no sound but the unit powered on and connected to Bluetooth just fine. Once I installed the antenna harness everything worked. So for those of you who have a similar issue, you need to make sure you have both the 28 pin harness (PT546-00120-CH) and the antenna harness (PT546-00120-AD). I believe the cause of this "no sound" issue is the fact that the antenna harness also supplies power to the amplifier.
As an aside, I've read in several places that Canadian model tCs came equipped with Toyota's BLU Logic system as standard. I noticed when I had the head unit removed that the BLU Logic system intercepts the main harnesses on the tC. The regular OEM harness plugs into the BLU Logic harness, which then connects into the radio. So for those with BLU Logic systems installed you will need to unhook these connections (2 plugs) and ensure you plug the OEM harness into the new head unit. If you leave them connected you will still get sound but you will have two Bluetooth connections now and it can get confusing. Although the microphone appears to be the same design as the OEM Toyota microphone you can buy separately, the BLU Logic microphone does NOT plug into the new radio or the new 28 pin harness (you will notice the 28 pin harness has 2 ends, one large end for the main connection, and the second smaller end is for a microphone).
Hopefully this helps someone in the future as I was unable to find any threads with a solution to this issue.
_________
_________
Hey everyone,
I know its been a while for most on this post but what parts did people use to get the Bluetooth to work, microphone, USB connection (if needed) and conversion harnesses for the swap. I bought a 2011tc for a back up car and the current radio is driving me nuts! Lol
Hey everyone,
At this point, these are fairly old cars and few Toyota dealers even know what a Scion tC is anymore. I would actually suggest you buy an aftermarket head unit which would have all the functions you are looking for without the need to source rare and hard-to-find parts. Crutchfield has a good selection and incredible support, that would be the place I recommend you shop if you end up going aftermarket.
The parts place gave me the head unit and all the speakers for cheap cheap which is why I decided to do this route instead of aftermarket. I'm not looking for great quality just that it works and I can connect via Bluetooth haha.
Ahh, gotcha. So the microphone that is standard in 2012+ models (and I'm sure other Toyota/Scion models) is located in the map light/sunroof switch trim located on the ceiling. The microphone has a built in amplifier so you are stuck having to source the OEM part if you are looking to retrofit bluetooth voice functions. Aftermarket microphones will NOT work because they are not amplified. If you are handy with electricals/circuitry/soldering I'm sure you could build your own wiring to connect the OEM microphone to your head unit. Your best bet, if you don't want to get into making your own harness, is to locate a tC in a self-serve salvage yard. That way you can rip open the trim and get the microphone and harness yourself.
If you manage to get it done, make sure to let the community know how it went. This stuff is pretty uncharted territory and would be nice for future users to have something to reference if they decide to do it themselves.
pfdumigan
Scion tC 2G ICE & Interior
08-11-2013 08:10 PM
Max
03-23-2005 04:43 AM
