2005 xA slight buzz at 3,500 rpms
Old 02-17-2016, 02:17 PM
Farnsrocket's Avatar
Default 2005 xA slight buzz at 3,500 rpms
Hello, just picked up a 2005 xA last week with 158k miles in great shape. I really love this little car!
I noticed at 3,500 rpms, there is a slight buzz in the engine....I can feel it in my seat and through the floor. It does it in every gear and at any speed as I am driving. If I keep accelerating, the buzzing stops at like 3800 or so.
Is this the VVT-i working? Maybe the valves need adjusting or is this normal?
Thanks for any help or info!
Farnsrocket is offline
Old 02-19-2016, 10:41 PM
168 views and no ideas?
Old 09-16-2016, 11:55 PM
Connollyir's Avatar
Hello Farnsrocket,
I actually made this account specifically to reply to this post. Are you still having this problem or did you get it fixed? I purchased my 06' XA with 128k and it also had this issue, which was quite annoying because the car sits at 3500rpm @ 70mph, my normal highway speed. Like you this happened in all gears, regardless of speed, beginning about 3300 and ending about 3800 - and only when the car is in gear.
So just FYI these are the repairs I have made to date:
New rear axle and axle seals
New brakes and rotors
New wheels and tires
New control arms
Front end alignment
New belts (both)
Clean throttle body
2 full cans of Seafoam run through fuel system during several fuel-ups (premium fuel)
New Accel coil packs
Iridium plugs
Replace airbox with Injen CAI and TBS
Replace intake manifold with Weapon R model
Replace exhaust header with Weapon R model
New stage 2 clutch from Clutchmasters
New light flywheel from Clutchmasters
Theres more but I am losing track... the last part with the clutch kit and flywheel was specifically done to address this 3500rpm vibe issue, the thought being my pilot bushing might be shot - clutch needed to be done anyway. I completed that job today and the test drive seems to indicate some of the vibration went away, but I will need more time to tell. The next step is replacing the exhaust from the header back with 2.5" pipe, a high flow cat, and a Flowmaster DBX muffler to get some better flow - hopefully smoothing things out further and fully utilizing the header/manifold/CAI/TBS combo.
I hope this helps if you are still having the issue, I will post back in a few days after I've had time to test the new clutch out.
-Ian
Connollyir is offline
Old 09-17-2016, 05:20 PM
Connollyir's Avatar
Ok so I did a pretty good amount of highway driving today and I can confirm that the new pilot bushing/clutch and flywheel has lessened the vibration but not eliminated it. Its definitely better than it was but its not perfect, certainly livable considering the the car is almost 11Y/O.
Perhaps this is also the frequency that my exhaust is resonating at.... New cat and muffler are on the way - will advise once they are installed.
-Ian
Old 10-04-2016, 05:34 PM
This ended up being a bad water pump for me!
hampton1100
06-19-2015 05:08 PM
Tc13
03-20-2015 04:02 PM
annika
03-16-2015 06:36 PM
iglooxb
15
07-25-2004 06:18 AM
jdtjunior
01-16-2004 06:20 PM
Quick Reply: 2005 xA slight buzz at 3,500 rpms
