Valve Adjustment
Old Mar 9, 2015 | 05:27 PM
Tc13's Avatar
Default Valve Adjustment
Hello,
I tried googling this subject but could not find any information regarding the 2ARFE.
Is there a way to adjust the valve lash on our cars?
Only thing I can think of is getting a thicker valve retainer cap.
Any input would be appriciated.
Thanks
Old Mar 12, 2015 | 06:54 AM
Red2014tC's Avatar
As far as I know, they are hydraulically adjusted like hydraulic lifters and therefore do not require lash adjustment.
Old Mar 12, 2015 | 09:14 AM
Krack808's Avatar
Originally Posted by Tc13
Hello,
Thanks
lifters comes in different thickness.
Old Mar 12, 2015 | 09:30 PM
Tc13's Avatar
Reason im asking is because,
I did that over rev while upshifting because i missed the gear and shifted down.
Pulled the valve cover checked the rocker roller " thing that cam pushes down to open the valve". It had poped out of place so i replaced. also the valve stem cap had came off so i placed it back. Now at different RPMS and when I start the vehicle i get a little bit of a chatter. And i still have little power loss in the upper rpm range. The issue all happened on cylinder 2 exhaust valve. just it might be out of adjustment.
Thanks for the help
Old Mar 14, 2015 | 11:54 PM
That_Kid_Ju's Avatar
Did your ecu go into limp mode? Did you try resetting it?
Old Mar 20, 2015 | 04:02 PM
Tc13's Avatar
I've reset it and I've got no CELs
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
SloTC1
Aug 16, 2018 02:45 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
