Fuel Filter replacement on xA..
Old 05-25-2014, 07:19 AM
blacknight_rc's Avatar
Default Fuel Filter replacement on xA..
Hi all,
I'm having a 2004 xA with 75k miles on it. I've never changed the fuel filter. Does mine have such a replaceable filter, or do I need to change it, if so how often?
____
blacknight_rc is offline
Old 05-25-2014, 07:24 AM
Originally Posted by blacknight_rc
Hi all,
I'm having a 2004 Xa with 75k miles on it. I've never changed the fuel filter. Does mine have such a replaceable filter, or do i need to change it, if so how often?
OK I just checked the owners' manual and it does have a fuel filter, but does not specify how often I should change it..
Old 05-25-2014, 07:16 PM
SatsumaxA's Avatar
The fuel filter is part of the fuel pump inside the fuel tank. This is under the rear seat and has an access panel to change out the pump/filter. There is no interval for changing the filter, usually not unless the fuel pump fails (usually due to filter) but I dont think its a seperate part available to purchase. At least the fuel tank doesn't have to be removed to replace!!!
SatsumaxA is offline
Old 05-27-2014, 12:16 PM
Hi SatsumaxA,
Thanks for your reply! OK then I wont be worried about it until i have some serious issue related to fuel (which i hope i wont)
Old 11-20-2015, 06:32 AM
Hi SatsumaxA,
Hi all,
I was having some vibrating issue (while on drive but braked, like at a stop light or traffic) and my mechanic told me its time for a tune up and fuel filter replacement (have 90k miles on it). So I did with genuine spares (it does have a replaceable fuel filter btw) and now it runs smoothly. Spark plugs I had used previously (NGK) were burnt out as well, replaced them with genuine spares. Hope this helps!
Cheers!
Miqmiqmiq
04-16-2016 02:34 AM
blh72
Scion xD Wheel & Tire
02-02-2015 12:36 AM
cid_mcdp
01-05-2015 02:45 PM
eric_m
79
03-17-2013 12:21 AM
dinkjs
02-22-2004 09:49 PM
Quick Reply: Fuel Filter replacement on xA..
