Automatic shift kits?
Old 07-14-2007, 11:30 PM
burkins89's Avatar
Default Automatic shift kits?
Does anyone know of companies that make them or a plug-in the recalibrates the shift points? I can't seem to find anyone that does and the ones that do are for late model muscle cars, etc.
burkins89 is offline
Old 07-15-2007, 02:58 AM
jct
jct's Avatar
no they do not i asked a few years ago and thats the answer that they gave me...
jct is offline
Old 07-15-2007, 03:13 AM
draxcaliber's Avatar
yeah, toyota makes one, it is called a manual transmission.
they make them for late model muscle cars because they didn't have computers and such.
you don't have a muscle car, you have a fairly new car with an electronically controlled transmission with nifty features so that it will automatically select the best gear for the car to be in based on mph, engine rpms, throttle position, and engine load.
you really can't improve on this other than say a valve body upgrade.
draxcaliber is offline
Old 07-15-2007, 12:02 PM
streetlethalxb's Avatar
I dropped a shift kit in a 4L60E electronically controlled
transmission.. worked great.. someone will make one oneday..
its basically a few springs and check valves, that are slightly
stronger/bigger.. as soon as the demand for rebuilding these
transmissions (by private shops) starts to happen, they tend
to follow.. just too new right now, and all of them still under
warranty.. demand is nill..
the trans is internally controlled differently, but it still comes down to an accumulator
creating a hydraulic action in the tranny, changing the accumulators internal spring with a softer one, will cause firmer shifts... they also do make the complete part for you to buy, but our cars aren't "old" enough yet..
heres an example of one for a 83-98 toyota automatic tranny
http://www.transmissionpartsusa.com/...00%2D09785523K
these guys would be your best bet for contacting about this..
http://www.levelten.com/store/import...rts_toyota.htm
streetlethalxb is offline
Old 04-15-2008, 03:48 AM
HotBox420's Avatar
back from the dead.... anyone make a shift kit yet?
HotBox420 is offline
Old 04-15-2008, 10:06 PM
Strictly Scionized
kzhorse's Avatar
This may be off but with the S-10 I had it was a electronic shift kit that wired into the ECM with 3 set points so I'm sure it could be done if you can find the pinout and figure what resistance to add.
Scott
kzhorse is offline
NonStopTuning
06-29-2015 07:42 PM
mischman
01-14-2015 06:07 PM
Scionxa180
Scion xA Aero & Exterior
01-08-2015 08:33 PM
scionaraxb
11-07-2003 08:16 PM
Quick Reply: Automatic shift kits?
