xB Tech and DIY Info for the Scion xB
A/C Control Color Change
Old Jun 19, 2004 | 10:49 PM
iglcrair's Avatar
I did this with my xA. Much of the disassembly of the console was the same. I couldnt find the rubber light covers in blue (AutoZone and Pepboys can suck it) so i attempted to use blue permanent marker. So far, seems to work. I am concerned about the bulb temperature burning off the ink, however. (Thats what happened when I tried the permanent marker on the dome light.)
I can take pictures of the process if anyone wants them. Shouldnt need them though, taking the thing apart is pretty cut and dried if youre cautious and look before you start yanking on stuff.
UPDATE:
Blue permanent marker is too dark. Gonna try turquoise. Guess its a hit or miss thing. Im thinking I might just have to jerry rig a series of LEDs into the console. Why Toyota tried to route such a low-wattage light through cheap clear plastic is beyond me... seems to be a stupid way to do things.
Old Jun 27, 2004 | 03:42 AM
Geneshaft's Avatar
how do you take off the xA's front panel? I don't want to break it.
GeneShaft
Old Jul 19, 2004 | 09:16 PM
CaliSciontCGirl's Avatar
Do you know if this would work on the tC as well?
Old Jul 21, 2004 | 02:07 AM
Jason_H's Avatar
GeneShaft
-pull off the silver sides
-remove left and right ****
-remove screws behind two *****
-lift up the piece from the bottom of where the ***** are, this piece extends up to where the stereo is
hope that helps
Old Jul 21, 2004 | 02:16 AM
mikochu's Avatar
GeneShaft
hope that helps
but very carefully :D
the silver accents may scratch your AC panel if you pull too hard...
also, watch out for the little ball bearing in the center **** assembley (it's greased up) That's the key to the CLICKY!
Old Jul 21, 2004 | 05:46 AM
renone's Avatar
DeepSouth Scions
Default replacment keds
http://www.superbrightleds.com/index.htm
why no just go here and get whatever color leds you want
direct fit or replacement
Old Jul 22, 2004 | 09:32 PM
Blakbox's Avatar
anyone got a part number for this thing?
Old Jul 23, 2004 | 10:15 PM
buildingrome's Avatar
i work for michaels scion in bellevue WA.
there is no separate part number for the little led's behind the dash or speedo
sorry
Old Aug 2, 2004 | 03:28 AM
SilyOtter's Avatar
Default Dash Light a/c control
cool pics. i think i can handle that. .. wish i woudl have done it when i put in my JVC head unit, does it look like you could pull the bulb out of the gray colored base? .. i changed the color of my shifter console bulb from whtie to red LED.. bulb #74 if those are the same they should pop in if the gray base pops off
2005 XB thundercloud metallic http://members.sounddomain.com/silyotter
SilyOtter's Avatar
Old Aug 2, 2004 | 06:39 PM
rican14's Avatar
i found some blue light bulb covers at autobarn.com
Old Aug 8, 2004 | 03:17 AM
scionlife89's Avatar
Default clock light
anyone know how to change the light behind the clock cuz if u chance the a/c controls to any color then the clock wont match it.
stephen hull
2005 black xb
Old Aug 10, 2004 | 02:31 AM
breunor's Avatar
As I was too lazy to buy the bulb covers (it was late) I just used a sharpie on some scotch tape and taped the bulbs with that. Seems to work from what I could see so far, might be a little dark though.
Old Aug 10, 2004 | 07:27 PM
mine turned out sweet thanks for posting it
Old Aug 12, 2004 | 08:48 AM
xBRAT's Avatar
scionlife89, did you use the bulb covers?
Old Aug 12, 2004 | 09:03 AM
xBRAT's Avatar
Default Speedhut.com LEDs
Go to www.speedhut.com and into their "accessories" section and click on the "6 high bright LEDs button. Here's what it says about them:
6 High Bright LEDs
Set of 6 LEDs. These LEDs will replace factory bulbs and change the stock lighting to a blue, red or green color. Use These LEDs to replace your stock bulbs to a different color. These LEDs never burn out. Most cars have 6 or less bulbs.
Wonder if these would work for the dash lights and what not??? Is somebody willing to get them and try them?
Old Aug 12, 2004 | 10:49 PM
Buebie's Avatar
MN Scions
When I go to Autozone what do I ask the clerk? Where are your rubber bulb cover things? What i'm getting at, is there a more technical name that will not make me look like the dumb blond?
Old Aug 13, 2004 | 02:35 AM
rican14's Avatar
go to autobarn.com in the search box put light bulb covers.
Old Aug 17, 2004 | 09:14 PM
rican14's Avatar
Default covers
well i just put my blue light bulb covers.have to wait till tonite to see how it looks.now how i`nm i going to change the shifter and the clock light to blue.
Old Aug 17, 2004 | 11:39 PM
rican14's Avatar
Default on button
ok,now the on button just slides into the next slot.before it used to click into the next slot.i as careful on removing the thing. :oops:
