Rear end
Old 03-17-2014, 04:32 PM
scionxb1stgen's Avatar
Default Rear end
If the bar in the rear has a slight (1/2'' to 1'') bend in it how will it affect the car,nothing noticeable in drive around the block.Should it be replaced?
scionxb1stgen is offline
Old 03-17-2014, 05:48 PM
criminaltc's Avatar
We don't have a rear end. What are you talking about? What bar? Picture please.
criminaltc is offline
Old 03-17-2014, 05:58 PM
jct
jct's Avatar
she's talking about the beam in the rear axle beam. it is totally normal for it to be there. if your really concerned about it you can buy an aftermarket rear swaybar
jct is offline
Old 03-17-2014, 06:06 PM
criminaltc's Avatar
This thing is a she?
Old 03-17-2014, 06:53 PM
Default rear end (Axle)
Yes , should of been more specific .Every one I 1st spoke with called the rear axle ,the rear end. And you're right,when I looked under the car for the first time for the rear end as we know for most cars,I couldn't find one not knowing that for some people the rear axle is the rear end.The main point is that it sounds like a small bend in axle is ok.Thanks!
Old 03-18-2014, 05:07 AM
jct
jct's Avatar
jct is offline
Old 03-18-2014, 05:52 AM
Red2014tC's Avatar
That part that is bent does not spin, the rear wheels spin on independent bearings. The "Bar" is a torsion bar to allow some flex in the rear beam, but not enough to bend or break it. This type of suspension is called a torsion beam, and is sometimes called "semi-independent suspension."
There are ones that I have seen that are curved or bent on purpose by design, and as I cannot see any damage in the pictures you posted, I assume it is supposed to be like that. Of the xB's I have worked on, I didn't pay to much attention to that area so I cannot say for sure 100%.
Red2014tC is offline
Ferretgrrl
10-15-2018 02:50 AM
NewBox06
02-03-2015 04:02 AM
ScionVan
11
12-02-2003 09:37 PM
smilygo
11-01-2003 11:26 PM
Kodokan_4
10-29-2003 05:49 AM
Quick Reply: Rear end
