tire size for 20's
Old Sep 12, 2004 | 04:07 AM
hotlava2061's Avatar
Default tire size for 20's
For all you ballers that are going to run 20's the rumor of the nitto 225/35/20 fitting with minor mods IS NOT TRUE. I had a set and i cut out all the innner fender side skirt that i could i beat the inner metal with a hammer they do not work trust me if you want i can prove it. You have to run the BFG 225/30/20 then you are all good
Old Sep 12, 2004 | 06:06 AM
chucksu's Avatar
I can see why a 225/35R20 would not work. The 225/30R20 is 25.5" tall, thats the same size as the stock bB 185/65R15 tire. Going with the 225/35R20 would make it even taller so you would be having some major problems unless you never needed to turn.
Old Sep 17, 2004 | 01:45 AM
2GoBx's Avatar
Was most of this trouble in the front??? How did the tires fit in the back, and what went in to getting them in there. I am thinking of doing a stager fit with 18's in the front and 20's in the back? If you can answer this it might save me some time and money. Oh, if you don't mind what type of wheels are they on. Size and offset would be great. Thanks for the help and info..
Old Sep 22, 2004 | 02:05 AM
LavabB's Avatar
StyleWagons
The man is right about the 225/35's, I had the same issues. And the 225/30's are friggin
expensive! like $300ea! From my recollection, the rears are actually harder than
the front to stuff in there. I have litterally a 1/4" gap from the face of the tire to the
metal that used to be behind the fender plastic, and thats after some "massaging"
If want my 2 cents, skip the 20's, just get 19's.... they bolt up.
-belly.
First in DFDub to roll 20's (?)
evolving_machine
12
Jan 18, 2016 08:41 PM
scionlife
371
Jun 2, 2015 11:00 PM
kingofthecrate
Jan 21, 2015 09:28 PM
debris
Dec 16, 2003 11:50 PM
BUzzBUcket
10
Oct 12, 2003 07:19 PM
