RPM at 60 and 80 MPH with 5 speed
Old 05-06-2007, 12:58 PM
forby's Avatar
Default RPM at 60 and 80 MPH with 5 speed
My biggest comlaint about the Xb original is that at 80 MPH with stock tires and a 5 speed, the RPM's are at like 4000!!!
Can someone clue me in as to the numbers on the new Xb with a stick?
I realize that the 1.5 need more RPM's (HP) to overcome the air resistance at those speeds. My wifes Honda EX V6 with an auto is at like 2600RPM's at 80!
forby is offline
Old 05-06-2007, 03:22 PM
stew32's Avatar
Since it's the same engine as tC, I assume it's the same manual trans and numbers would be the identical. So what's that? Car and Driver says 21.6 MPH per 1,000 RPMs in 5th gear for a tC. So 2,700 RPM @ 60 MPH, 3,700 RPM @ 80?
http://www.caranddriver.com/roadtest...-tc-page4.html
stew32 is offline
Old 05-06-2007, 04:18 PM
Bigfieroman's Avatar
The xB actually uses a little bit taller tire than the tC, and that has an effect.
I come to ~2750 (tC close to 2800) at 60mph and about 3660 at 80 mph.
I was under the impression that the old xB ran at something like 4500+ at 80 mph?
Bigfieroman is offline
Old 05-06-2007, 05:19 PM
stew32's Avatar
1st gen xB with manual is approx 4,000 RPM at an indicated 80 MPH. Still really high though.
stew32 is offline
Old 05-06-2007, 05:38 PM
Admin Emeritus
Tomas's Avatar
The figures for the Original xBs have been posted and discussed many times:
AUTOMATIC:
2560 RPM @ 60 MPH
2990 RPM @ 70 MPH
3410 RPM @ 80 MPH
MANUAL:
3070 RPM @ 60 MPH
3580 RPM @ 70 MPH
4090 RPM @ 80 MPH
Checking the dealer booklet for the new xB2, I get the following:
Tire size: 205/55R16
Final drive ratio: 4.235M / 2.74A
Top gear ratio: 0.731M / 1.020A
and that means:
835 * 4.235 * 0.731 = 2585 RPM at 60 MPH manual
835 * 2.74 * 1.020 = 2334 RPM at 60 MPH automatic
(rev per mile) * (final ratio) * (top gear ratio) = (engine RPM at 60MPH)
So, for the manual transmission xB2:
2585 RPM @ 60 MPH
3015 RPM @ 70 MPH
3445 RPM @ 80 MPH
plus or minus 10 RPM.
For the automatic transmission xB2:
2335 RPM @ 60 MPH
2725 RPM @ 70 MPH
3115 RPM @ 80 MPH
(Damned tpyos.)
Tomas is offline
Old 05-06-2007, 07:25 PM
OldYeller's Avatar
4000 is a couple of thousand+ below redline. Is it the noise you don't like or do you think it is wearing out the engine. These engines are made for high revs.........
OldYeller is offline
Old 05-11-2007, 01:08 PM
forby's Avatar
Thanks for all the replies....
I have been busy lately and unable to repond to this thread.
I am concerned about the noise mostly. At 80Mph it seems like I'm in a blender!!!
The new Xb seems to be about 650RPM's lower!!!!
That should make for a really quite drive.
forby is offline
Old 05-20-2007, 10:44 PM
Ethereal_Dragon's Avatar
It's about the gas savings too... at least thats what I would think...
Ethereal_Dragon is offline
Old 05-21-2007, 01:15 AM
Admin Emeritus
Tomas's Avatar
The manual transmission '08 xB2 is wound just a little bit tighter than the automatic transmission '03-'06 xB.
Tom
Tomas is offline
Old 07-12-2007, 12:56 PM
chadfo's Avatar
You don't have to worry about noise in the XB2. It's MUCH quieter than the XB1. With the stock muffler you can't really hear any engine noise once you level off at a given speed.
chadfo is offline
Fisqual
09-22-2015 05:51 AM
mgaines
06-14-2015 11:39 PM
Steelerfanmatt07
06-05-2015 03:07 AM
annika
03-16-2015 06:36 PM
Wide_tC
01-15-2004 01:00 PM
Quick Reply: RPM at 60 and 80 MPH with 5 speed
