Pics of my "mods" 56k beware
Team Sushi
Before:
After:
TRD Springs
Bluebatmobile redout tails
Suprascionxb style intake
90mm shortee "Carantenna"
For more pics go to
http://photos.yahoo.com/djct_watt
After:
TRD Springs
For more pics go to
Lookin' good, djct_watt! I was thinking of getting tein s-techs, but then I heard they are real low. Then I thought about getting those TRDs...I might get those or the Eibachs... How do you like the ride? Also, what headlights did you buy/install?
Team Sushi
too lazy to set up a website right now. . . here's a direct link
http://pg.photos.yahoo.com/ph/djct_w...watt/my_photos
Team Sushi
I love the TRD ride. . . it's much better than stock, but compliant enough to not jar my bones. I can't really tell a difference when I'm driving normally, but when I take a turn hard, I definitely feel the difference! The kit is enough to give the xA the aggressive stance I want, without being too low as well, and the white springs match the car!
Now, with the improved the suspension, the tires have become obsolete (as if they weren't to begin with). The car tracks nice and flat (a little less body roll would be nice, but any stiffer and long term wear could/can become a problem), but the tires easily cook, and the way I drive, it is uncommon to lose traction. But the limit is really high, so it's not much of a problem. . . I just like to test that limit as often as I can :twisted: . The other point, is now that I've improved the suspension, I feel more confident to test that limit. Before, when the car started to lose traction, it would pitch and dive and roll wildly. . . which is all but gone now. Oh. . . I do notice more whell hop tho. . . The up side of these crappo tires is that they are inexpensive to replace.
I would love to have the car dropped until it nearly touches the ground, but past experiences have given me too many headaches, as well as many of my friends.
Team Sushi
And the headlights are DOT approved, street legal, APC superwhites. I don't want to be melting any wires, and for street legal superwhites, they are pretty cheap ($12). Sylverstars are nicer IMO, but more $$ and they do burn out fast. I've been through tons of brands in my old car, and found APC's to not be THAT bad. The fog bulbs are Nokya 9006 Hyper-Yellow's. Parking lights are also superwhites.
I want HID, but there output from the stock bulb/housing combinations of good enough for me.
Team Sushi
You wouldn't believe how easy it is. . . you just go in through the wheel wells. . . it's not that much of a reach, and that flimsy plastic is real easy to pull back. It takes less that 1 minute. Just rotate the base counter clockwise a few notches, then pull. Undo the wiring harness, and you're done.
xBrelease08
12
Feb 29, 2016 05:39 AM
