need Headlight help
Old Aug 27, 2007 | 01:32 AM
coregmrconman's Avatar
Default need Headlight help
does anyone know if 9006 hids will work with these
thanks all.
Old Aug 27, 2007 | 02:07 AM
low_down_xb's Avatar
i have those lights and you need a h3 for low beam and h1 for highs
Old Aug 27, 2007 | 02:21 AM
will 9006 fit?
Old Aug 27, 2007 | 02:55 AM
no, you need h3 bulbs
Old Aug 27, 2007 | 04:05 AM
what about these....
Old Aug 27, 2007 | 03:13 PM
i think you can use the 9006 with those
Old Aug 30, 2007 | 11:06 PM
NEGATIVE211's Avatar
i have those lights u just posted, but the driver side doesn't have as much lighting power as the passenger side.
Old Aug 30, 2007 | 11:43 PM
dmpsk8's Avatar
you may already know this but ill state just in case. u cant just wire hids into the sonars. ur gonna need a relay setup
Old Aug 31, 2007 | 01:20 AM
burstaneurysm's Avatar
^ what? If you meant he needs a full HID setup then yes. But it's not different what housing you use. HID is HID, as long as you have the right lamp, it will work. HID runs cooler than halogen too, so heat isn't an issue.
Old Aug 31, 2007 | 02:58 AM
dmpsk8's Avatar
yeah. to be more clear:
https://www.scionlife.com/forums/vie...d+stock+wiring
Old Aug 31, 2007 | 03:00 AM
dmpsk8's Avatar
and btw those lens in the sonars are nothing like the Blue-ion ones i have. they are way blue-er
Old Aug 31, 2007 | 04:56 AM
Originally Posted by dmpsk8
Yea, you meant HID harness... it still uses the stock relay, but it needs a new harness to prevent the stock harness from burning up.
Old Sep 2, 2007 | 08:52 AM
i have hids for about 6 months on some other housings. (the ones with 3 little leds under the lamp) so i have an hid setup. i just need to know if hids will "fit" in them.
Old Sep 2, 2007 | 08:55 AM
n btw i dont want them more blue dmp. my cars red n black. that would look weird.
Old Sep 2, 2007 | 06:27 PM
YES hid will work in the new lamps and NO your old bulbs WILL NOT FIT in those new housings, geeeeezzzzzz..............................................
Old Sep 7, 2007 | 12:36 PM
XBooster's Avatar
Default Re: need Headlight help
thanks all.
where did you bought them??? Ebay?? How much??
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
DannyBoy65
Sep 21, 2015 06:23 PM
atlantaemail
Sep 20, 2015 02:03 AM
