Dumb question...how do you connect a tap splice?
Old Jan 4, 2008 | 05:46 PM
Conambo's Avatar
Default Dumb question...how do you connect a tap splice?
The black wire, are you supposed to strip that wire? or just leave it unstripped and slide it in?
Also, do you crimp down the metal part with alot of force or just enough to close it?
I don't even know why in the pic, they are splicing red and black together.
Anyways, thanks!
Old Jan 4, 2008 | 06:17 PM
frame's Avatar
That picture is wrong. The black wire is really suppose to be the red wire (Unless you are using the black wire in place of a red wire). But you don't strip that wire, just slide the wire in and push hard on it till the clip pops into place (use pliers).
basically when you have both the wires inplace and crimp the metal part will slice into the main wire and the wire you are trying to get power to, acting as a bridge for current
Old Jan 4, 2008 | 06:26 PM
bluaeon's Avatar
what i usually do is strip the wire and then tap it. hahaha strip then tap... nice! LOL
Old Jan 4, 2008 | 06:41 PM
blazeplacid's Avatar
no stripping needed.
stick the orignal wire in the bigger slot.
stick the new wire in the small short hole.
Get some pliers squeeze and squeeze till you hear the plastic "latch" piece clip
easy once you do it.
might wanna practice on two wires that are connected to nothing first to get the feel
Old Jan 4, 2008 | 06:55 PM
Conambo's Avatar
Cool.....no stripping for me. Thanks!
Old Jan 4, 2008 | 10:34 PM
engifineer's Avatar
Throw them in the trash and solder it if you want a good connection that will last I have seen more of those end up causing headaches than anything else. Unless I am hooking up something like trailer brakes on a boat trailer I will never use those.
But, if you must use them, dont strip as mentioned, just put the wire in and mash it together.
Old Jan 4, 2008 | 10:51 PM
Conambo's Avatar
Damn...I just bought a box of them at Home Depot, too.
I guess I'll return them. The more I am reading about them on the web, says the same thing. They are crap!
Old Jan 5, 2008 | 12:52 AM
tclicious's Avatar
Omg
Old Jan 7, 2008 | 02:28 AM
SW_08's Avatar
exactly what he said....although i wasnt the one who did them.....
thanks expresscion
yupinmytC
22
Jul 27, 2024 07:08 PM
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
